carb
Old Jul 22, 2011 | 10:00 AM
berndog's Avatar
berndog
Default carb
So yesterday on my keihin carb,I removed it pulled float bowl off changed accel pump put in new o rings cleaned it up,turned the one jet so it suirts more mid carb,put back on bike,now front cyl seems to be getting real hot real fast,misses ,revs good at low throttle,but I get up to 60 - 70 kmh and starts crappin out,like noe fuel? maybe I se the float too low or what.
Old Jul 22, 2011 | 11:08 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Intake leak...
Old Jul 22, 2011 | 01:01 PM
megawatt's Avatar
megawatt
It may be the dread intake leak if the missing is taking place at low speed.
You may have set the float bowl level too low or there is a piece of crud in the high speed circuit restricting fuel flow at higher speeds.
Old Jul 22, 2011 | 07:21 PM
48pan's Avatar
48pan
My guess would be an intake leak since it's isolated to the front cylinder getting hot. Get it running and spray the clamps with carb cleaner and if there's a leak the rpm will increase. good luck. keep those shovels running.
Old Jul 24, 2011 | 12:24 PM
berndog's Avatar
berndog
So I pulled the carb and manifold off,cleaned out the carb readjusted the float a bit higher replaced everything except jets and outer components,used 2 gaskets ,back to back on intake,gasket glued the intake and carb surface,mounted gaskets back to back,easy on tightening of band clamps,changed petcock,advanced timing ,unfortunately by ear,,fired up right away,no problem idling at warm up rode to the city and back,never performed so good.Twice as i turned off,it ran on for a minute,and spit about a cup of fuel out the overflow,while parked ,realized the new petcock reserve is where the old one was off,,tapped the floatbowl with a wrench,,,she runs great,,,,just wondering about the run on now.
This is a wonderful forum,learning so much,Thanks Guys
Old Jul 24, 2011 | 02:37 PM
TwiZted Biker's Avatar
TwiZted Biker
A bit more advance on the timing . If you got the manual depending on whether you have points or electronic the static timing procedure will get you damn close if not on the money , within 2 degrees when I light check them .
bigjayree
EVO
Sep 14, 2015 04:05 PM
kiowadriver
Shovelhead
Oct 13, 2010 06:19 PM
greezymonkee
EVO
22
Oct 28, 2007 07:34 PM
rnelson664
Exhaust System Topics
Feb 15, 2007 01:48 PM
Shovelhead77
Ironhead
Jun 3, 2006 09:45 PM
