82 FXB Sturgis.....deal or moneypit?
I recently came across an opportunity to pick up an '82 FXB, a carbon copy of my beloved Sturgis stolen over 25 years ago. Decent price, but here is the kicker:
It has been sitting in inside storage for 10 years without having been run! So think 10 year old fuel, 10 year old oils, dead electric, and so on.
ASSUMING for the sake of conversation the bike was sound mechanically prior to inactivity, what are member's opinions on the financial risk in taking this on? Is it still an opportunity......or bankruptcy waiting to happen?
All opinions matter!
Thanks in advance.
New tires and battery.
Made and installed larger battery cables. May not have really needed them but they looked small to me and I was having kick back problems which I thought was the starter being weak.
Pulled primary cover and cleaned out all the yuk at the bottom.
Replaced the degraded primary chain oiler hose inside the primary.
Dissebled and cleaned oil from the dry clutch plates.
Checked primary chain tension.
Pumped out oil tank and swabbed the tank completely clean.
Pulled oil filter and cranked engine with spark plugs out to drain as much as possible. Engine had been run before starting the oil changing and cleaning.
Ran new oil/filter with heavy duty sludge removal additive for a short time, driving very easily to get the oil hot but not loading the engine and then did #s 5 and 6 again. I changed the oil and filter again after a couple of hundred miles.
Replaced trani oil a couple of times.
Dissembled carburator and cleaned it out everywhere. S&S super E and the cold start orifice in the bowl was clogged. Rest cleaned up OK. Checked carb to intake seals and clamps. Installed new throttle cables.
New air cleaner element
Checked oil screan on fuel pump, it was OK
Checked timing, it was out badly. Engine would kick back against starter sometimes which ruined the bendix drive before I understood what was going on.
Checked hydraulic lifter settings.
Checked all the electrical connections and followed the wires looking for chafed spots and repaired.
Drained and replaced both brake fluids and fork oil.
Replaced fork seals. They failed shortly after starting to ride a lot.
New o-ring chain, closed off the auto oiler.
Greased rear wheel bearings while wheel was out.
Replaced front wheel bearings, water must have got in as they were rusted.
Lubed speedo cable and drive gear at the hub while the wheel was out
Replaced the degraded first front brake line to the tee with new steel braid.
Replaced handle bar mount elastomers
Removed and cleaned the fuel tank out as best as possible and cleaned the screen often for quite a while after. Fuel filter may need replacing. I replaced the gas cap. If the vent sticks the engine can run lean or quit all together.
Aligned engine/rear wheel. Rubber mounted engine on an FXR.
Replaced coil and spark plug cables after riding a while.
Checked out exhaust pipe mounting and seals to make sure all was OK.
Seat was bad and installed a used seat set from a FXRT which my wife likes.
Lubed the pedel and lever bearings.
Since I did all this the bike has been very reliable. I've never had a Harley before and doing all this really let me know what I have and how to take care of it. Most of the parts I got online or from an independant Harley repair shop which was much cheeper than from a dealer and they usually know more about old bikes. Most of this stuff is what would have been done as normal maintenance anyway.
Again I thank you.
If there is rust, you will probably wear out the rings fairly quickly, could experience valve sticking, etc.
If you can get your hands on a borescope, turn the engine until the piston in the cylinder being checked is at bottom dead center, so you can see as much as possible of the wall.
If you do buy it, and have the option, fill the cylinders with Marvel Mystery oil, and let them soak overnight before turning the engine over. Spray some through the intake tract to hit the valve stems as well.
Depending on the condition, price, and your ability to work on it, it could be a great opportunity, or it could be a money pit.
Edited to add TIRES!
Edited to add that it also depends on whether intake or exhaust valves are open when the engine stops.
