intake leak
Old May 15, 2012 | 10:19 PM
bigzdogz's Avatar
bigzdogz
Default intake leak
need some ideas. I have replaced the carb to a s&s super b w/ intake. There happens to be an ideal problom. I used a smoke machine in the carb and found the intake bands were leaking. Replaced the bands and started same stumble checked with smoke again smoke pured out of bands on both sides. Any help
Old May 16, 2012 | 11:16 AM
msgtarmor's Avatar
msgtarmor
Are you using the 2 piece clamps? I have found they work great sometimes, other times they suck (literaly). The 1 piece stainless band clamps are a pain but work best. I would start again and make sure that before you tighten the intake clamps the carb is in position for the aircleaner and support bracket to mount right up without movin the carb. If you've done all that and have the right clamps, then I dont know. The band on the best 1 piece clamps overlap so your rubberband is totaly covered and evenly tight.
Another cause for the carb to not run well is the throttle shaft worn out in the carb body. Grab the ends one at a time and see if there is any forward or backward movement. If you can feel movement, remove it and inspect it. If the holes in the carb body are egged out you will need to have throttle shaft bushings machined into it. If the shaft has worn replace it. That will suck air causing inconsistant idle and in worst case the shaft to bind, causing the throttle to stick open (not fun)!! You can get rebuild kits for the B that include the throttle shaft bushings. As a matter of fact I noticed on the S&S website you can still get a brand new super B carb.
Hope this helps!
jim
Old May 16, 2012 | 01:34 PM
bigzdogz's Avatar
bigzdogz
I have rebuilt the carb and the butterfly shaft is oe and tight. I am pretty sure the ideal problem is due to the bands. I have the one piece metal bands on now.
Old May 16, 2012 | 01:45 PM
ROTTEN ROB's Avatar
ROTTEN ROB
Just snug the clamps,if you get crazy with them ,it will distort the bands and cause a intake leak.The bracket is most important,it holds the carb,not the bands and clamps.........
Old May 16, 2012 | 10:36 PM
05rkstd's Avatar
05rkstd
Try one wrap of electrical tape around the joints, then the clamps slightly tight. The carb support should be holding weight..if that makes any sence.
Old May 24, 2012 | 10:39 PM
bigzdogz's Avatar
bigzdogz
So I found these plastic o rings that fit on the lower lip of the intake and the block. Then I took the bands and put them on. Then I used regular hose clamps and smoke tested. Perfect no leak. Now lets get the timming set.
Old May 25, 2012 | 12:46 PM
flh80's Avatar
flh80
You'd be beter of with the Aircraft style "T" bolt clamps
izzyfutch
Ironhead
Nov 22, 2017 04:23 PM
buellxb422
Ironhead
Apr 25, 2016 08:13 AM
Sho71vel
Shovelhead
Mar 20, 2012 02:47 PM
sheem2153
Exhaust System Topics
May 13, 2010 10:16 AM
chardagha
EVO
May 3, 2010 04:28 PM
