Dead speedometer
Old Jan 12, 2007 | 12:30 AM
TATER's Avatar
TATER
6th Gear
Default Dead speedometer
[align=left]Ok guys, time to pick your brains.
77 Lowrider. The speedometer does nothing at any speed. I pulled the dash off to see if the cable was screwed. Seems OK. I dont have a way to elevate front tire yet or I would give it a spin.
So how should I go about testing the speedometer.
[/align][align=left] [/align]
Old Jan 12, 2007 | 12:54 AM
Punky Brewster's Avatar
Punky Brewster
Default RE: Dead speedometer
Sounds like the speedo cable broke.Unscrew from the back of the guage.Once you have the cable(top end) in your hand start to unscrew from front tire.I'm almost positive the cable is shot
Old Jan 12, 2007 | 01:58 AM
TATER's Avatar
TATER
6th Gear
Cable shot.End of cable broken and stuck inside drive unit. Thanks.
Old Jan 12, 2007 | 02:13 AM
TATER's Avatar
TATER
6th Gear
Old Jan 12, 2007 | 11:08 PM
TATER's Avatar
TATER
6th Gear
Old Jan 14, 2007 | 12:11 AM
Punky Brewster
ORIGINAL: TATER
[align=left][/align]
Did you get the broken piece out?
Old Jan 14, 2007 | 05:20 PM
TATER's Avatar
TATER
6th Gear
I cant yank the broken piece out. I pulled the gear out to see if I could drive it out w/ a punch.. No dice.
New drive unit coming. I got a cable from local indy shop for cheap.
Old Jan 14, 2007 | 05:50 PM
Punky Brewster
ORIGINAL: TATER
Damn that sucks,cables are usually a cheap fix.Usually the cable breaks from the speedo end
T Tommyt
May 24, 2008 05:37 PM
deaf1
Mar 15, 2008 10:33 PM
robandlyn
Jun 1, 2007 03:43 PM
