Pipes and Carb Help
Old Jul 12, 2012 | 03:46 AM
biginchhustler's Avatar
biginchhustler
Default all about spark plugs
---- http://www.bikerenews.com/Stories_Ar...park_Plugs.htm --
Old Jul 12, 2012 | 03:51 AM
TwiZted Biker's Avatar
TwiZted Biker
Originally Posted by biginchhustler
Your a night owl too Run's in the type blood we have I think .
Old Jul 12, 2012 | 06:39 AM
biginchhustler
nahhhh we work till the wee hours next month we flip hours.. and when bored use the company PC lol QC can get away wih that ..
Old Jul 15, 2012 | 08:44 PM
shovelhead FXEF's Avatar
shovelhead FXEF
Originally Posted by AJSHOVEL
Go with your 1 3/4" pipes and switch to a .070 main. If you want it to run even better, look into khrome werks baffles, or at least a bolt or lollypop.
Which Krome Werks do you recommend ? Thanks
Old Jul 16, 2012 | 03:15 AM
biginchhustler
heres the link to the lolliepop washer/bolt
--- http://www.nightrider.com/biketech/exhaust.htm --
"quote from site"
"Make a tunable baffle by purchasing a 1/4"x1" thumb screw or taking a 3/4" outside diameter washer and weld it to the top of a 3/4" x 1/4" bolt. Now Drill a 1/4" hole about 1" from the end of the drag pipes. Take the tunable baffle and place a 1/4" nut and a lock washer (away from the large washer) the on it. Now insert your tunable baffle into the exhaust pipe like the example below.
Old Jul 16, 2012 | 09:53 AM
AJSHOVEL's Avatar
AJSHOVEL
The HP Plus baffles for 1 3/4" drags.
Old Jul 30, 2012 | 07:32 PM
shovelhead FXEF
Well S&S box states 72 main jet, .295 intermediate jet. Took off bottom cover to get to main jet and found it had a 74 in it. Put in the 70 along with the 1 3/4 pipes and Khrome Werks baffles. Ran the bike a bunch this weekend and what a huge difference. Only problem now is off idle to 1500 RPM. Seems to be a little fat still. Guess I should brake open carb completely to double check .295. If this is bigger, could that be my low end issue?
Old Jul 30, 2012 | 10:16 PM
TwiZted Biker
Check the accelerator pump action seen more that a few where they where dribbling gas in constantly from over travel made the bikes real rich but the jets where fine .
seoris
May 9, 2010 05:41 PM
Doug S
Aug 26, 2009 06:42 AM
kwadrillion
Ironhead
Mar 17, 2008 05:07 PM
michiganlarry
Exhaust System Topics
22
Jul 19, 2007 07:59 AM
sickshovel
Jun 19, 2006 11:44 AM
