Front End Question
Old Jan 20, 2007 | 01:12 PM
1911shooter's Avatar
1911shooter
Default Front End Question
I need some technical help. I plan to put a FL front end on my '83 Shovel this winter and go with a 16" front wheel. My question is will later style front ends fit my 4 - speed frame style? I'm getting mixed messages and I have found a couple of later style front ends on Ebay but I want to know what will work. Any and all help will be appreciated!
Old Feb 20, 2007 | 12:30 AM
scootertrash's Avatar
scootertrash
Default RE: Front End Question
a new flh wont work. if you don't mind losing the fork lock a soft tail will.(heritage or fatboy) I'm running a 2001 deuce front end on a 78 fxs with no problems. not sure about a roadking type tripletree.
Old Feb 21, 2007 | 02:45 AM
imboden's Avatar
imboden
ORIGINAL: scootertrash
sweet news for me, I wanna puta new front end on a 79FXS. Did you have to loose the lock on it too?
Old Feb 21, 2007 | 08:40 PM
scootertrash
the lock on the deuce front end does not line up with the frame so it doesn't work other then that it bolted right up.
Old Feb 21, 2007 | 08:50 PM
scootertrash
recentlly put a set of fatboy trees on a '79 fxwith 2004 flht legs. Needed a bigger mastercylinder to run the dual disc brakes but it fit well enough, but again no fork lock.
Old Feb 22, 2007 | 04:46 PM
tedali2004's Avatar
tedali2004
If you check out my gallery you can see a pic of my '76 FXE with a 1997 Fatboy frontend. I will have to go back and see what was done to the tree to get the fork lock to line up. I will let you know later. I wanted to have dual disc also, but I didn't want to pay for new Roadking lower legs after building the bike the way it sits.
Old Mar 10, 2007 | 09:51 PM
tedali2004's Avatar
tedali2004
So here are some pics up close of my '75 FXE with a '97 FLST front end. The front end was ordered as a unit from HD through the Gainesville, FL HD dealer. The lock lined up fine, I'm not sure what year after was switched to the newer lock style.
Panimal
Oct 6, 2013 12:46 PM
rusty1200
Dec 21, 2009 09:01 AM
car5car
Oct 25, 2009 06:56 PM
Jonny Cannon
Aug 6, 2009 10:24 AM
Naz_Man
Mar 16, 2006 02:20 AM
