custom shovel
Old Sep 23, 2012 | 07:54 PM
mooseye's Avatar
mooseye
Default custom shovel
I have just become the owner of a '76 shovelhead which has been mounted on a late model frame.
It has duel discs front and disc rear brakes, fatbob tank, and mag wheels.
I hope I did not screw up!
The owner said the engine was totally rebuilt about 4 years ago and only ridden about 5000 miles since. It starts easy and seems to run well but does have a few oil leaks. It definitely has some electrical issues as the headlight, blinkers, and horn do not work.
I did get a good title with it and a point of origin for the frame.
Do you guys think it would be worth a little more than a stock unit with the newer frame and disc brakes and mags and such? Or would OEM be more desirable?
I know it don't matter now since I paid cash for it, but a little reassurance is always nice.
Old Sep 23, 2012 | 08:08 PM
Tom84FXST's Avatar
Tom84FXST
IMO dead stock is always worth more money on the older bikes.
Old Sep 23, 2012 | 08:16 PM
mooseye's Avatar
mooseye
I was afraid someone would say that.
Oh well, its only money!
Old Sep 23, 2012 | 09:09 PM
Captain Itch's Avatar
Captain Itch
Sponsor
About those oil leaks..When it quits leaking that usually means that it is empty..
Enjoy that Shovel..
__________________
www.Captain-Itch.com
Old Sep 23, 2012 | 11:05 PM
user 697208202's Avatar
user 697208202
Default same Boat ...
I too just purchased a 76 FLH Shovel and am also having oil leaks. I knew this before buying it though as according to a lot of people this goes with the territory with them. But it is certainly leaking a lot more than I thought it would.
Also have some electrical issues, but I am looking forward to restoring this beauty.
Good luck with it ...
Old Sep 24, 2012 | 11:07 AM
mooseye's Avatar
mooseye
Thanks Matty,
Same to you.
I understand about the oil, lol.
I was kindof thinking about doing something besides restoring mine. It has already been altered from stock so much it would be like starting over with just the engine.
I am hoping to learn some about the shovelhead engine though.
I am not even really sure what it is yet. I did get it in my name this morning so it is mine now.
The title says it is an Ultima, which I think is just an aftermarket build with an older engine.
Maybe some of the highly knowledgeable folks here can offer some info.
Old Sep 24, 2012 | 09:15 PM
TwiZted Biker's Avatar
TwiZted Biker
As long as you can work out the paperwork with no issues you should be good to go all shovels are going up in price pretty steady but OEM does bring a bit higher tag for resale .
Oil leaks are an easy fix guys , post up when your ready and I'll give you the low down on what you need parts & gaskets wise & how to's to cure them just take'a a little time and attention to detail that's all . My shovels don't leak period .
Old Sep 24, 2012 | 09:35 PM
mooseye's Avatar
mooseye
Thanks for the response TwiZted.
I want to do a lot to the bike, but I have only gravel to work on for now. I am planning a small shop soon and want to fix everything on the Shovel.
Till then, I am like a sponge.
I found out the hard way this afternoon that the screw that appears to be the idle speed on the right/towards the front of bike is not. I ran it in trying to increase the idle only to find that it would not start due to no accel. pump action. It has an s&s super e on it. I am now in the know about super e's thanks to their website.
I will be looking forward to using your methods to stop the downpour as soon as I have a clean dry place to dissemble it.
I have always had to work on everything I own in the rocks of my driveway. Not fun!
atengnr
Ironhead
Feb 18, 2015 09:11 AM
LiiT
Aug 29, 2014 09:39 PM
Simple Man
Dec 18, 2012 12:34 PM
alfajuj
Custom Models
Nov 27, 2012 10:50 PM
CSA
Custom Models
May 25, 2008 04:31 PM
