Potential buy, need help!
Old Nov 10, 2012 | 02:10 PM
vinsanity's Avatar
vinsanity
Stage IV
Default Potential buy, need help!
This bike last ran 2 yrs ago. The ad said that the oil and gas were drained for storage. Why would someone drain oil? The guy says it turns over. Is there anything in the pic I should be worried about? Can the rust around the kicker be removed? If I bought this bike what should be done first? I want to bring it back to life and turn it into a daily rider.
Attached Thumbnails Potential buy, need help!-2012-11-07-10.18.53.jpg   Potential buy, need help!-2012-11-07-10.17.09.jpg
Old Nov 10, 2012 | 03:32 PM
44caliberkid's Avatar
44caliberkid
Engine oil can break down over time. Especially if it has run in the engine and is contaminated. For storing for years, yes, drain the oil. The rust is probably from the kicker shaft, it should clean off, but will come back. If the lever is rusted, they don't cost much.
I'd be more interested in the price.
Old Nov 10, 2012 | 03:39 PM
Captain Itch's Avatar
Captain Itch
Sponsor
Not sure what mechanical skills you may have, but you Probably will have more issues to worry about than some rust around the kicker. The tranny seals,and other gaskets leak oil,just a fact of life.If you want it to be reliable you will need to go through the entire bike that way you know what you have..Around here in Tennessee that bike the way it sits would go between 3-4 grand.
__________________
www.Captain-Itch.com
Old Nov 10, 2012 | 03:51 PM
Krutch's Avatar
Krutch
From: somewhere in "The Peoples' Republic of Illinois
Sitting for a couple years shouldn't hurt it. Unless it was outside all that time. It don't look it was out side.
You can expect to sink some $'s into it. The rear brake disc should be cleaned or replaced. Maybe whole brake system.
Old oil has acids and crap in it and can cause pitting. Oil drained should have been replaced new oil. Reason it wasn't could be because of "by-pass". Oil seeps by the check valve and collects in the lower end. Not harmful in itself. Looks bad if ya fire up in front of potential buyer and puking occures.
I'd want to hear it run before buying. Not knowing why it sat. Could be it needs high $'s and owner didn't want to spend them.
Old Nov 10, 2012 | 10:18 PM
vinzilla's Avatar
vinzilla
Thanks guys, The seller mentioned that the bike had brake problems and that he has all the parts. He's asking $3500 and I have a 6 hour drive to pick it up. I've been looking for awhile and there isn't many shovelheads in my area (Saskatchewan). When it comes to doing the maintenance on the bike I'm not worried, I'm worried about the $$$. I'm a military aircraft technician and I've cleaned up one Twin cam Dyna already. I just haven't done enough research yet. I watched 6Over a couple weeks ago and it got me pumped up about shovelheads.
Old Nov 11, 2012 | 07:46 AM
AlCherry's Avatar
AlCherry
That old scoot is gonna have to be gone through completely, meaning everything out of the frame, frame blasted and checked for cracks, engine and trans rebuilt, all seals and bearings replaced in the wheels and swingarm, brakes rebuilt and probably a rewiring.
That may sound difficult, but if you have the time and money, you'll get a good result. I would probably take 30 hundred dollar bills with me and flash 20 of them after talking about the down side of the bike for a while. Work up the price at 250 dollar increments and stop at 3 grand. I wouldn't pay more than that.
Old Nov 11, 2012 | 09:09 AM
vinsanity's Avatar
vinsanity
Stage IV
Thanks AlCherry, I was pricing parts out last night and I was hoping someone would tell me it's worth less then 3 grand.
Old Nov 12, 2012 | 06:30 PM
AlCherry's Avatar
AlCherry
It's going to be a labor of love. You'll never get the money out of it that you are going to put into it. Take your time and do it right. What you can't do, find a reputable builder to do it.
Old Nov 14, 2012 | 05:08 PM
vinsanity's Avatar
vinsanity
Stage IV
So I talked the guy down over the phone and he said he'd take $2800. But, I asked again how long was the bike sitting and he said 7 years this time. And apparently a harley tech was the one who prepped it for storage.
If there's nothing seized and I put new plugs in, oil and fuel and try to turn it over with the electric starter. Whats the worst that can happen? Oil pissing out fire?
Is there anything else I should check?
Old Nov 14, 2012 | 07:10 PM
Captain Itch
Sponsor
Ok let me try to explain as to what you can expect just to get this rolling on its own..A fresh battery,starter, solenoid,and relay,and points. Shovels sort of have their little quirks with the electric starting parts and circuits.,so you need to look at all of this.The fuel system carb rebuild,fuel lines,rust in tank ? Oil lines for leaks.Make sure oil is returning to the tank...Heads and the top end need more attention than the newer bikes as a rule.Now if you get it running check the tranny out put shaft for leaks as the seals have a way of leaking..Sprockets and chains how much wear ? Breaks and tires cause you want to be safe and being able to stop is always a plus. I am not trying to scare you away from this at all,depending on what you want out of this bike it may be the one for you..Shovels are a lot of fun.Last year at this time I bought a 73 with original paint and 23,000 miles. I knew this bike for 15 years and when I bought it,it ran and shifted like it should but the starter clutch would drag and I heard a little noise in the front cylinder that I did not like..After pulling the motor a part I rebuilt it completely and sent the heads out to get done..New seals in the tranny,new clutch,rewire entire bike,Breaks..All types of other stuff but it all adds up but now I know what I have and am not worried about going down the road..Sorry for all of my rambling,and leaving you more confused than ever..
