4 speed transmission rebuild Help
Well here is my first issue. I pulled the countershaft and I am pretty sure the needle bearing are loose in there. I can't get the counter shaft gear cluster out.
Issue two. Pulling the starter clutch hub. I don't really want to go buy a $200 puller right now. I am currently a student and don't have that kind of loose change.
I am currently going to a motorcycle school in central FL... I am sure people are already rolling their eyes. If there is anyone around that has been turning wrenches and would want to show me a thing or two I would love the help.
Also any other tips would be greatly appreciated. The manual I have isn't the easiest to follow for greenhorns like myself.
Thanks
"Buy the tools" & the HD Manual if you have not done so already...
The Clymer & Haynes are worthless IMHO; although I have been greatly disappointed in the HD one too at times...
You will end up spending more in the long run by not buying the right tools to begin with...
So if you don't have the dough now... wait ... it will be worth the price of admission...
The only tool I could not find for any price was the "Starter Clutch Puller HD-95650-42" and "Jims" is currently out of stock with no ETA...
I did some googling and found that IF you are careful you can use a two-finger or three finger puller as a substitute; you can buy them cheap or you can rent one from autozone and get 100% of your money back when your done...
hard to beat that for cost...
I had no trouble with the substitute puller...
The HD manual says pull the counter shaft first and the counter shaft gear does have two needle bearings in it...
IF you are following the HD manual and you have a pick/scribe/coat hanger or whatever you should be able to fish the counter shaft washer out and bump the whole assembly out with a small piece of wood or something...
Search ebay for "Shovelhead Panhead spacer o-ring leak free transmission" sellers handle is "saddlebagrail" he sells the fix for the built-in-oil leak from HD... about $45.00 bucks to your front door
This video shows you how to DIY or what you need to pay somebody to do... if you don't want to buy it from saddlebagrail
You probably need to replace the spacer anyway, may as well fix it good...
Haste makes waste... and lack of patience will cost you dough...
Thanks
As has been mentioned...OEM manual and parts book are a "must have". Harbor Freight sells cheap tools at a cheap price. Another place for decent priced s tuff is Enco.
The tool you will definitely need is the Adjusting Shifter Gauge in order to align the shift drum and shifter clutch/gears. You may think you can eyeball for center-to-center but most likely you won't which means you put it all back together, run it and do not grab all gears, which means you take it all apart again because you did not do it correctly the firts time because you figured you could go without it. Either you buy it, borrow it, or take it someplace and have them check to make sure it is within specs...which means someone else is doing your work, and if I don't trust them with my life the partciular motor work gets done by me and doesn't get farmed out. Last thing you need is to be stuck on a long stretch of lonesome because someone did a $hitty job on your rebuild.
Here's a little tip on that unless you change the shifting forks themselves or change out the entire ratchet lid the new gears & shift dogs will go in and not need any adjusting 99% of the time , you've got some wiggle room with the old 4 speeds .
The poor mans way to do it and it takes a little time and some common sense is assemble the gears in the box leave it dry the gently put the lid on and find neutral , spin the mainshaft a few times to roll everything inside over several turns . Now gently work the top straight up and peek inside at the shift dogs , they should be both centered up pretty well , if so your usually good to go . But for a novice I would repeat the procedure and shift it into first gears , turn the mainshaft a few times and lift the top straight up again and see how the shift dog is engaging in the gear . Do this for 1st through 4 th . If any of the dogs don't look like they are seating all the way , take it to a local Indy and have them set by a pro , you'll be money ahead trust me .
I've done the same as you and mixed them before but I did mic everything so all the sizes where the same per side & went back accordingly .
