gear play
Old Dec 18, 2012 | 05:48 PM
biginchhustler's Avatar
biginchhustler
Default gear play
i took my belt drive off today because every now and then ya have to clean and re-grease the rollers -- when i had everything out -- i noticed that if i put the bike in gear and grabbed the hub i could turn it back and forth like in feeling the shifter dogs -- it turns to the left till it comes in contact with i guess the shifter dog -- and then to the right till it hits like you can feel it make contact with the gear when you put the bike in gear -- is this normal?? it rides and shifts fine -- its like its takes the play out as you rotate the hub -- only in gear and all 4 gears -- <--->
Old Dec 18, 2012 | 10:51 PM
TwiZted Biker's Avatar
TwiZted Biker
Yeah there's some room in the slots on the gears for the dogs to rock & forth in , you can get a good 1/8 or more of the shaft rotation back & forth on some . As long as she isn't hard going into or pops out of gear under load and no whining noises your good on a 4 speed . Takes some to screw one up as long as you keep oil in it .
fdh161
Sep 24, 2014 12:35 PM
gliderman
Oct 3, 2013 05:17 PM
roundy
Aug 13, 2012 06:22 AM
DAYTONCHOPPERS
Jul 19, 2011 08:32 AM
sutphen30
Ironhead
Oct 15, 2008 02:50 PM
