Power Loss
Old Jun 6, 2013 | 12:12 PM
  #31
biginchhustler's Avatar
biginchhustler
engines like the old model T had no over lap -- no real duration --- the valves opened @ 0 and closed @ 0 hence the reason the sounded like they did -- theres more to it than overlap -- cam profile -- base circle - asymmetrical - symmetrical - single pattern -- dual pattern -- constant velocity -- continuous acceleration -- fast ramp cams --- blah blah blah --
like my sons turbo -- 577 lift -- 239 duration -- intake valve opens @ 3 atdc -- not 30 btdc but after -- reason? turbo boost duration and overlap would let the charge go out the exhaust --
F.I. is like 6 btdc where a regular carb is like 30 btdc and closes @ 60 abdc
  #32
Joe12RK's Avatar
Joe12RK
Originally Posted by JohnnyC
I've had second thoughts about both valves being open at the same time.
I believe there is a point where on the intake or exhaust stroke you have both valves open in a short overlap. If this is true (?) then your observation of both being open at the same time COULD BE normal.
Indeed; but he remove all four pushrods so the valves were as closed as possible.
Old Jun 6, 2013 | 07:36 PM
  #33
johnjzjz's Avatar
johnjzjz
Here's an article about the overlap.
Here's a motor animation.
in a hemi motor the TDC lift ( both valves open at the same time - intake closing and exhaust opening it given in thousands on any cam card for checking - example like .203 intake / .187 exhaust the methiod used to check this is a tool that attaches to the head, and with checker springs and 2 dial gages you open to the number < .203 intake / .187 exhaust than the distance between the 2 valves never should be less than .040 with a harley overhead motor ( hemi overhead ) the valves at the angle they are, this is a thing to check when caming the motor as well as valve to piston and that is different to check and how -- hope that helps - jz
Old Sep 2, 2013 | 02:53 PM
  #34
American Made's Avatar
American Made
Default The problem
Ok first I want to thank everyone who took time to reply to my inquiry, second I want to apologize for abandoning the thread til now.
First, the leak down test was accurate. The head was leaking out both valves. I installed a pair of S&S heads & problem solved.
The reason I choose the S&S heads was simply they were in stock. To have my heads gone through wouldn't of been much cheaper & would of had to wait.
Thank you again to everyone that contributed.
CRoadster
Carburetor Related
May 29, 2018 09:38 PM
jus2anoyu
EVO
Aug 1, 2015 08:16 AM
mykechambers
Ironhead
Aug 10, 2014 09:53 AM
Ironshovel7178
Ironhead
Jan 9, 2012 08:46 PM
