Comprehensive list and of shovelhead reliability issues and solutions
buy an evo and leave the shovels to us.. there only gonna ride them in fair weather -- or only on wed night and stand there and say "I looked in the gas tank today so that makes me a master tech..
"we're going on a "run" sunday but first we will trailer it 300 miles and ride it 25 miles around a state park in full costume..
My attempt at this thread was to develop an all encompassing knowledge base of design flaws, such that I and any others interested can understand what needs to be done to a stock shovelhead that may or may not have been properly fixed to make the bike relatively reliable.
As I mentioned, I am looking for design flaws such as oiling issues etc. I'm looking for what isn't written in the manuals, and Twiztid I will pm you with my non-junk email address for use when your book is available for purchase. Access to written knowledge is always appreciated.
Also before I forget to ask: Has anyone reading this rubber mounted a shovel that didn't come rubber mounted? I'd assume that you'd have to get the torch out and modify the mounting brackets. Any experience out there with this?
I build them shovels are my thing have been over 30 years and 90% of the time all the horror stories you hear about are owner induced from outright neglect and running them into the ground or flat out ignorance , seriously not joking . I've put a half million miles on shovels , they can't be that bad .
Interesting how you use the term "relatively reliable" like there is some doubt that they are not. Think about it…would a 29-45 year-old bike even be on the road today if an owner somewhere at some pont in time didn't fix what was wrong, be it design flaws, mechanical flaws, human error flaws. You got to think that somoeone before you came along fixed the problem or the bike would not be on the road today.
'36 knuckles had oil consumtion problems but you still see a few 36 knuckles runnning around (because someone, somewhere way before us "fixed " the problem).
Early pan motors ('48 t0 L'52) came with hydraulic pushrods. Problem is that the hydraulic units were at the top of the pushrod and oil does not like to pump up, especially on cold mornings. My 49 would not even be around if the original owner hadn't taken those out and installed solids ("fixed" the problem). Hell I don't even know of anyone running the original hydraulics.
And here's nugget for you, lest you think I am only including something you have no interest in. Service Bulletin 593 (7/12/69), states that rocker cover gaskets begin use on 69 E-Glides starting in May 8, 1969. Have to say that I have never, ever seen a Shovel top end w/o these (why…because someone, somewhere "fixed" the probem since theye were able to be retrofitted back to '66 modles).
You would be better off looking for a shovel that interests you and then getting knitty-gritty with the seller and looking for specifics re: what has been done to the bike along with receipts/proof of work done and modifications. There are still a few barn-find shovels out there. If you find one then you can look for specifics for that particular model/year should you desire to restore it.
FYI...MoCo issued Service Bulletins through the years that listed some of the issues with their bikes. I have copies of Service Shop Dope III ('41-65) and IV ('62-69). I think these are still available through places like J&P Cycles. I have originals of Service Bulletins '63-76. If you find a particlular year that you are looking at I can check my Sevice Bulletins to see if there are any problems listed. And lastly the 63-76 bulletins were part of the student material provided at the HD Service School. One of these days I will find the 76-84 info.
ADDED thought…if you want to read up on the changes to the Shovel over the years it was produced (and you have to believe that for the most part, HD made the changes to improve their product), probably the best reading material (IMHO anyway) is Donny Peterson's "Unauthorized Technical Guide to Harley Davidson 1936 to Present. So far he has done paperbacks on the Twinks, Evos and has two volumes on Shovels 1966-1985. Some of the material is redundant but in a positive way. He is working on ones for Panheads. if you decide you want to step back farther in time and look for a pan, the best book out there is Bruce Palmers, "How to Restore Your Harley Davidson".
Banana caliper bushings wear and the caliper wobbles and sags... there is a specific support with a spring to keep it up and prevent this. Or upgrade to Twin Cam 4 piston calipers... you find TONS of take off for little money
Voltage regulator is something that at some point died on my 3 shovels
Ignition: if you have points, upgrade to a heavy duty stainless steel advance unit
Once u get the bike replace the oil lines
Brake lines: if they are rubber and old, replace them, better if stainless steel braided lines
Keep primary and final chain within specs
Starter: upgrade to spike starter
Upgrade to 32 amp charging system
Check and replace all wiring fixes and old hard wires
Shifting can be sloppy: check and replace shifting leverages bushings
