as was said DONT go looking to fix things that are not broken
I wouldn't be looking to upgrade or change anything on a bike that I haven't ridden yet, unless obviously broken or worn out. You may wind up liking it the way it is, esp if it's been in your family. They ran in stock form for many many years. Improvements are good things, but not necessary. Ride it and enjoy it for a season then tear it apart to fix things you really don't like. Joe
ps nice bike.
Understood and point taken. Obviously this bike has tremendous sentimental value to me. I'm not looking to really change much from the way my uncle had it. I simply want to do what's best for the bike, and to make sure it's mechanically sound.
This is exactly why I started this thread. To get different suggestions and ideas before I do anything. I really appreciate all the input.
That bike is a piece of AMF junk! It will never run good and will suck up thousands of dollars better spent somewhere else. Shoot me your address and I'll come take that scrap heap off your hands...
I kick started my '77 FXE for 11 years-never felt the need for electronic ignition. Spend the money for the necessary items to fire it first.
Points can be fixed on the road,what do you do with a little 'blackbox' if it craps out 100 miles from home? [pull the 'black box',and re-install the points to get home]!!
Dyna 'S' ignitions are simply contact-less magnetic points. There is no black box. It's all mechanical ( just like points.)
IIRC, back when I had my 76 FXE, we used to use the same spark plugs as was used in a 283 c.i. Chevy engine, and the same points as was used in a Chevy 6 cylinder engine.
Don't forget to install a new condenser and also the compliance fittings (tubes from carb to heads).
A little squirt of Liquid Wrench in the plug holes before slowly kicking it over couldn't hurt, and having someone check to see that the points are breaking and firing at the same time would be a good idea.
