VIN missing .....or location
Old Mar 1, 2014 | 09:34 PM
wing83fxwg's Avatar
wing83fxwg
Stage IV
Default VIN missing .....or location
I'm not having a good feeling about this, long story short, The law asked for my papers when I unloaded bike at a dealership and the tag didn't match (was just using ramp to get it 3 blocks to home) he looked at frame said you need to clean off the VIN so it can be read, he took my info and said he would check back 1st of week.
well i can't find the numbers .. the last part of VIN is on the motor but frame nothing I cleaned off the powdercoating to look. the marks are from a razor blade I used.. I hope this is not what I'm thinking it is A paughco frame? it doesn't look like a stock 83 fxwg frame neck area
Old Mar 1, 2014 | 11:14 PM
hoghead5150's Avatar
hoghead5150
i have a paughco frame on my bike. on the right side (throttle side) there is a long number stamped into the neck, BUT they didn't use that as the vin on my bike. on the left side (clutch side) there is a white basically paper tag with a number on it. that is the number the dmv used to tag mine. wish they would have used the stamped number!!
Old Mar 2, 2014 | 12:29 AM
wing83fxwg's Avatar
wing83fxwg
Stage IV
does this frame neck area look same as yours?
Old Mar 2, 2014 | 11:15 AM
Tom84FXST's Avatar
Tom84FXST
I don't believe that is a stock frame...It should have a rectangular flat area on the frame tube for the vin...and a hole for the fork lock.
Old Mar 2, 2014 | 12:55 PM
wing83fxwg's Avatar
wing83fxwg
Stage IV
I searched the entire neck area NO dice BUT i did check the lower front motor mount area bingo found a 17 digit number starting with a 4B7H469 space 7 more numbers then 2 more I heard Kraft tech had serial numbers there so i looked and found these
brad75raiders
EVO
25
May 15, 2018 07:14 PM
Cal516
Aug 17, 2017 07:58 AM
IronMike1661
Aug 7, 2014 07:33 AM
I_am_10_ninjas
May 2, 2011 06:13 PM
Kev_England
Aug 30, 2010 09:38 AM
