anyone still run the stock primary chain oiler?
Old Sep 3, 2014 | 11:35 AM
pjb's Avatar
pjb
OK, I installed the original chain set up, and installed all new oil lines. I also replaced the outer primary cover because the old one had vents in it for the belt system. The new primary cover has an extra hole at the bottom, where the old one had that hole only partially drilled out. The new cover has a pretty good leak that seems to be coming from that extra hole. How do I fix it?
Old Sep 3, 2014 | 12:21 PM
V_twins's Avatar
V_twins
primary drain hole?
Buy the oem magnetic plug
Old Sep 3, 2014 | 12:24 PM
pjb's Avatar
pjb
No. An extra bolt hole in the bottom rear of the outer cover itself.
Old Sep 3, 2014 | 01:39 PM
pjb's Avatar
pjb
I should have gotten a primary cover that did not have the 9th hole drilled all the way thru.
Too late now. Any ideas how to plug the unused 9th hole?
Old Sep 3, 2014 | 03:14 PM
FilthyLucre's Avatar
FilthyLucre
A cheap fix would to be to fill it with JB Weld
1Fordman
Shovelhead
Jun 18, 2018 08:15 AM
eugenetaylor
Jun 12, 2012 11:49 AM
TCMAN
Apr 2, 2011 07:20 PM
rxdug
Shovelhead
Jan 29, 2010 09:25 PM
beeoh
Shovelhead
23
Mar 9, 2008 10:37 PM
