2012 Ultra Primary Fill
Old Jun 12, 2012 | 11:43 AM
eugenetaylor's Avatar
eugenetaylor
Default 2012 Ultra Primary Fill
QUESTION???
How much are you guy's putting back in your primary when you change it?
Owners manual says 38oz. But when I drained it, got 45oz out of it. Harley shop did 1000 mile service earlier. Changed to (Redline Primary oil) in hopes of quieting chain noise done. It made a difference. Tried the MOBIL 1, but way worse than Harley Lube.
Old Jun 12, 2012 | 11:46 AM
stro1965's Avatar
stro1965
Should be 38 ounces "wet". It's only 45 if you start with a dry primary. As long as it's just touching the bottom of the clutch plates you're OK.
Old Jun 12, 2012 | 11:49 AM
mkguitar's Avatar
mkguitar
"about 38 oz"
the primary is checked/filled to the level as described in the manual.
this is not crucial- BUT too much lube causes drag on the parts, not enough can wear the clutch.
when I do my primary I work the clutch to get what i can out of the mechanism, and sometimes let drain overnight with a zip tie on the lever.
then I fill it so that the level is just over the clutch with bike on the jiffy.
the HD primary lube works great.
******** more lube in the primary than you remember putting in can be a sign of a bad seal in the motor and oil being forced into the primary.
This was also a problem 20 years ago in evos with porous cases, the oil was seeping through the case into the primary
mike
JONNIEROCK
Sep 2, 2016 08:33 PM
128auto
EVO
11
Mar 11, 2014 06:50 AM
Dougcass
Jul 19, 2011 08:01 AM
nemick
Aug 2, 2010 01:05 PM
jepps
13
Jun 28, 2008 09:25 AM
