who's been having to add transmission fluid?
Im putting a couple of hundred miles Saturday and plan to leave it in 5th on the interstate.
I work at a tool and die shop, and have looked at your relieved cover before, and thought I might have one machined here at work.
Last fall, one of Harley's master technician from Milwaukee was at my dealer. I did not let him install the primary vent at that time.
I thought Harley would come up with a real fix before this spring.
I did talk to this technician about relieving the cover to let the transmission fluid drain quicker away from the transmission shaft opening.
Told him that he / Harley should review all the information on this forum..
I still have about 10 months left on my warranty, and I am going to let Harley try one more time.
I also think this primary vent is a "Band-Aid", and Harley really needs to figure this out.
If the primary is really pulling a vacuum, I need to know why. There is something wrong that a vent will not fix.
If the primary vent does not work, I will probably install the "fat" clutch actuator rod (PrMan) and also relieve the side cover.
So there are M8 covers with the center cut all the way out? Were you using alumna-burrs or regular ones. Seems to me an alumna-burrs on a decent tool would wack that out pretty quickly.
