H-D fan assisted oil cooler
Old Jul 11, 2019 | 09:56 PM
$tonecold's Avatar
$tonecold
Originally Posted by craigffb
do you happen to have the part number?
26800095
Old Jul 12, 2019 | 07:25 AM
Greg Di's Avatar
Greg Di
What's the deal with the flash? Can it be done with a power vision?
I'm already running a 124 so I'm way off the factory tune.
Thanks
Old Jul 12, 2019 | 08:26 AM
craigffb's Avatar
craigffb
Originally Posted by Just Cruzin'
I did exactly what you are thinking on my 2018 FLTRXS. Cutting off top tabs and mounting tabs on stock cooler and installing the modified fan assisted unit took about an hour. Sorry but no pics but it has been working well for a year. Good luck.
Originally Posted by wmprof
Same here. Bought fan only from Surdyke. Dealer flashed for free.
Can either of you guys give a little more info on this?
Thanks
Old Jul 12, 2019 | 09:12 AM
$tonecold's Avatar
$tonecold
Thanks
I don’t know about the PowerVision, but a TTS can turn on this fan and the Cool Flow fan.
Old Jul 12, 2019 | 01:08 PM
wmprof's Avatar
wmprof
Thanks
Just figured I didn't need to have two oil coolers. Pretty simple process, remove the factory oil cooler, cut off the tabs for mounting and Snap-on the fan. Touched up paint where I cut off the tabs. Reinstall oil cooler with two new clamps on the bottom of the hoses only and plug in.
Had the dealer turn on the option 4 fan. Not really a flash, just like turning on speakers or turning on lights on brights and stuff.
Old Jul 12, 2019 | 01:45 PM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
i.e. The mounting tabs on the non-fan oil cooler are in the way of the fan shroud. The fan-assisted oil cooler moves the mounting tabs from the oil cooler to the fan shroud (meaning the oil cooler itself does not need mounting tabs).
Non-fan oil cooler: 62700196
Fan-assisted oil cooler: 62700133
Fan: 26800095
Fan-assisted oil cooler kit (fan and fan-friendly oil cooler): 62700204
Old Jul 12, 2019 | 02:40 PM
craigffb's Avatar
craigffb
Fan: 26800095
Thanks for the info guys.
JJHOG
May 1, 2012 11:03 AM
drewski1325
Mar 27, 2012 10:57 PM
GeorgeWW
Jan 8, 2011 02:52 PM
roadWorrier
Oil Archive (no new posts)
Sep 12, 2009 07:16 PM
cycleboy1450
Jun 27, 2008 02:22 PM
