Oil Coolers HD or Jagg?
Old Jan 15, 2012 | 09:25 PM
JJHOG's Avatar
JJHOG
Default Oil Coolers HD or Jagg?
Just did a 96 to 103 and would like to know owners thoughts on installing an oil cooler? I understand they come stock on 2012 103" bikes. What's your experience with the Jagg 10row cooler versus the HD Oil cooler?
Old Jan 15, 2012 | 10:25 PM
Morris9982's Avatar
Morris9982
I've had the HD and the Jagg fan assisted cooler both on my bike and I prefer the Jagg.
It runs cooler going down the road and I like the idea of the fan which seems to slow the rise in oil temperature when stuck in traffic.
As a side note, I bought the adapter with the thermostat from Jagg and it moves the filter up and forward away from what I think is the crank sensor. This will make changing the filter easier.
Old Jan 15, 2012 | 10:48 PM
Bluehighways's Avatar
Bluehighways
I have the HD on my 103" 2010. Seems to get the job done. Definitely dropped the oil temperature, and that's not easy when it's 112*F in the desert around here. Max seen is 220-230*F with the oil cooler, over 250*F without. As long as it stays under 250*F I'm a happy camper.
Old Jan 15, 2012 | 10:59 PM
WI Bob's Avatar
WI Bob
Old Jan 16, 2012 | 04:26 AM
Moneywoes's Avatar
Moneywoes
Oil bud cooler is another good option...
http://harleyoilcoolers.com/index.html
Old Jan 16, 2012 | 04:34 AM
GAZRNR's Avatar
GAZRNR
I run a Jagg 10 row on my RG. Install was easy and works great.
Old Jan 16, 2012 | 05:35 AM
tj316's Avatar
tj316
I took the HD unit off and went to Jagg , it dropped my temperatures well below where the HD unit kept them
Old Jan 16, 2012 | 08:15 AM
JJHOG's Avatar
JJHOG
Which Jagg unit did you install? Fan Cooled and just regular 10row low mount unit?
Old Jan 16, 2012 | 08:20 AM
rg_dave's Avatar
rg_dave
I installed the HD. 3 summers of over 100 degrees and I've never had any issues riding in town or on the highway. At the time I installed Jag didn't have one that I liked the look of. If I was doing it today I would probably go with the Jag fan assist model. I've never heard anything but good things about Jag coolers.
Old Jan 16, 2012 | 08:54 AM
Buddy WMC's Avatar
Buddy WMC
+1, mounted one on my 11 Tri Glide Ultra and also wired the fan to my acccesory switch through the thermoswitch. Now I can turn the fan on and off as needed. Can't buy a better product and Marv the owner of Jagg is very customer oriented.
