CA emissions bike - extreme gas smell
Anyone else with CA Touring bike that has had anything similar? I'll replace the gas cap this weekend. I've inspected the EVAP system as much as I could without tearing into it. I pulled the dash panel on the tank, all ok. There is no liquid gas leak.
Any input would be appreciated. Thanks.
2. Check you solenoid purge valve #5 and make sure the electrical connections are good and do not have corrosion.
3. If all the above is good, you may need a new carbon canister #7 if it is saturated.
4. Check your fuel line connection on the gas tank and make sure it is seated correctly, my not leak enough gas to be visible but enough to smell.
https://www.harley-davidson.com/us/e...63d5c2bf7390/y
I live in CA...
I've owned 2 CA Twin Cam bikes and currently still have one. It's an '03 I bought new, and has never smelled up my little garage/shop with fumes. I've filled it, and driven a couple miles home and parked it... no smells.
I have 3 Twin Cams I bought used and are not CA bikes. If I fill them before parking them, and don't drive at least 8-10 miles before parking, they will fill my little garage/shop with gas fumes in short order.
I suspect something in your venting side (shown in the above parts pic) is loose, broken, or disconnected.
FWIW...
The vent system is a one-way, directional system. The gas cap is a vacuum vented cap. It lets air into the tank, as fuel is used, to avoid building a vacuum in the tank. Then the vent through the tank plate, relieves positive pressure from the tank. It is the only way fumes (pressure) can escape the tank. The fumes are directed to the canister and/or back to the intake, via the purge valve solenoid. If the tank cap vented both ways, the canister system wouldn't work.. All fumes would take the path of least resistance and go in & out the cap.
A failed gas cap will usually allow vacuum to build... I guess it could be damaged and allow fumes to escape. However, I have never taken one apart to see just how it works, or if it failing open is even possible.
I live in CA...
FWIW...
The smell accumulates after it sits a while. Again, it's bad. I'm almost sure you're correct, its the canister and/or it's connections.
If I'm lucky, it's the fuel cap. The canister is in front of the battery box, correct? Thanks again, it's very much appreciated.
I have an '01 Springer that's not a CA bike. I've had that happen a few times. Seems to happen more the hottter the engine and the hotter the ambient temp...
At least I know my vent line isn't plugged...
