Noise coming from primary Buzzing/whirring
Old May 4, 2026 | 12:00 PM
Hossup's Avatar
Hossup
Default Noise coming from primary Buzzing/whirring
Greetings,
2006 Softail Deluxe,
I recently replaced both my inner and outer primary, and I am now getting a buzzing/whirring noise from the primary area. The noise does not seem to change with clutch engagement or acceleration. When I shut the engine off, it almost sounds like a squeal, as if something is tight while the engine comes to a stop.
I opened the inspection cover and confirmed the noise is definitely coming from the primary. I then removed the primary cover and did not see anything obviously loose, rubbing, or wearing abnormally. I checked the primary chain adjustment, and it is just over 5/8" upward deflection.
I took the bike for a short ride, about 5 miles. Everything felt smooth and handled normally. Engine noise and wind made it harder to hear while riding, but the noise did not seem to change or go away. When I got back to the garage, it seemed to quiet down slightly, but it was still present.
I have read through several forums and understand that bearings may be a possibility, but I am looking for constructive suggestions on what else to check before assuming the worst.
Has anyone run into a similar buzzing/whirring or shutdown squeal after replacing the inner and outer primary? Any practical checks or troubleshooting steps would be appreciated.
Old May 5, 2026 | 11:42 PM
Max Headflow's Avatar
Max Headflow
Installed the tensioner shoe backwards?
Old May 5, 2026 | 11:58 PM
miky2001's Avatar
miky2001
i bet the chain is too tight. the whirring sound usually comes from the bearing on the the transmission shaft when the chain is too tight, or if the bearing is old and needs to be replaced.
Old May 27, 2026 | 03:05 AM
Colvinb's Avatar
Colvinb
Did you change any bearings or seals while in there? Could be inner primary bearing/race. Or if you replaced the primary bearing seal, did you cover up the oil feed hole with the circlip? Just spit-balling here, cause just removing and installing the inner and outer primary covers shouldn't induce a "new" noise that wasn't there before.
Old May 27, 2026 | 03:16 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
If I tension the primary just a little too tight it makes possibly a similar noise when I shut off and coast.
Old Yesterday | 02:49 PM
Hossup's Avatar
Hossup
Nope I double checked it and replaced it with a Baker.
Old Yesterday | 02:51 PM
Hossup's Avatar
Hossup
I replaced the bearing with a Baker one-piece and all the seals.
Old Yesterday | 02:53 PM
Hossup's Avatar
Hossup
I adjusted it right at 5/8 play. I also took the tension off the belt. I will loosen up the chain and let you know on the chain tension.
Old Today | 02:09 PM
Hossup's Avatar
Hossup
So after completely removing the entire primary and all components and reinstalling I believe the cause was the starter pinion was too tight and wasn't retracting and was getting stuck on the flywheel.
mountains
Jul 21, 2023 12:11 PM
Khshockey44
EVO
31
Apr 5, 2017 03:42 PM
mtcrss546
Sep 7, 2016 04:24 PM
JONNIEROCK
Sep 4, 2010 08:32 AM
