Air pressure crankcase TC96
Old May 24, 2026 | 10:23 PM
jim70's Avatar
jim70
Default Air pressure crankcase TC96
I have a bone stock 2010 ultra glide with 30k.
When twisting, removing oil dipstick I get a prolonged rush of air emitting from case.
Even a 10 second run of engine will produce this air pressure.
No oil wetting around air filter.
No leaks anywhere.
Engine runs great.
Lessened oil level to halfway below full on stick.
I hear conflicting advice, even from dealer service departments…annoying.
Perhaps some in-depth reputable knowledge on our forum.
Don’t want to risk any damage in this state.
Thanks all.
Jim
Old May 24, 2026 | 10:28 PM
jim70's Avatar
jim70
Test.
Old May 24, 2026 | 10:29 PM
jim70's Avatar
jim70
Test
Old May 25, 2026 | 06:26 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Consider pulling the rocker boxes and replacing the breathers.
Old May 25, 2026 | 09:20 AM
bustert's Avatar
bustert
try a newer style breather as in the S&S style that does away with the stock foam oil extractor which can harden and coke up over time. those rubber umbrella valves also degrade and fail to seal.
Old May 25, 2026 | 10:15 AM
Schex's Avatar
Schex
Pull the A/C cover and pull the tubes off the breather bolts, put your finger over the holes with the engine running, see if you can feel pulsing, you can even pull the breather bolts and check.
After running with the tubes and/or bolts removed, see if it still has pressure when removing the dipstick.
If it does, need to go into the rocker boxes and dig into the breathers.
Old May 25, 2026 | 02:40 PM
jim70's Avatar
jim70
Great info.
I’ll give it a go when I get some down time.
Thx
Old May 25, 2026 | 02:59 PM
Rounders's Avatar
Rounders
Originally Posted by jim70
Great info.
Thx
All of the sudden not in a rush.
Old May 25, 2026 | 03:08 PM
MURPHCC1's Avatar
MURPHCC1
Where did he say he was in a rush?
Making shyt up again.
Old May 25, 2026 | 03:10 PM
Rounders's Avatar
Rounders
Test
Test.
Kinda seemed like he was in a rush
But do we need another 20 pages ?
I am shocked dan didn't bite his head off. Maybe turned over new leaf or holiday spirits
