Cycle Electric Rectifier
Old Jun 9, 2026 | 06:42 PM
76HDflh's Avatar
76HDflh
Default Cycle Electric Rectifier
Installing a Cycle Electric Kit on my 1976 FLH, bike is stock. If anyone has installed one of these Can you give me a little guidance. Rectifier #CE-605 has a wire going to stator, another wire, yellow tip, goes to circuit breaker, third wire goes to ground. Original rectifier had two wires, one to stator, the other goes to positive battery terminal . On the cycle electric rectifier does the yellow tip wire go to positive battery terminal or go into cone and attach to points. Does the wire marked grd get grounded to frame? The directions are not very clear about this. Thank you for any help.
Old Jun 9, 2026 | 06:58 PM
Max Headflow's Avatar
Max Headflow
The GND wire should got to battery ground. On a 76, it should be any good frame ground.
Old Jun 9, 2026 | 07:22 PM
76HDflh's Avatar
76HDflh
Thanks, does the yellow tip wire go to positive
battery terminal ?
Old Jun 9, 2026 | 10:09 PM
Max Headflow
Assuming this is correct.
"yellow tip, goes to circuit breaker"
It can go to the battery. That's where it goes on the wiring diagram. #3 is the regulator.
Old Yesterday | 05:29 AM
TwiZted Biker's Avatar
TwiZted Biker
Suggest you call them, customer service is pretty good with those guys.
Old Yesterday | 03:43 PM
76HDflh's Avatar
76HDflh
Thanks for help! I have the factory service manual and followed the wire. But as a DIY’er I was thrown by the circuit breaker reference. Contacted the company, nice people, Carl called me back and answered my questions. His suggestion was to put an inline fuse on the wire connecting to positive battery terminal. Another problem solved.
Old Yesterday | 04:34 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Years ago the factory used to connect the rectifier to the positive battery post (or the fusible link that was connected to the positive post), then they changed to connecting it to the silver stud on the main circuit breaker.
In the early `90s they changed again, to connecting the wire to the copper stud on the main circuit breaker, and I think this is the way Cycle Electric says to do it, even on the earlier bikes.
My `89 Softail originally came with the rectifier connected to the silver stud (output side) on the main breaker, but when I replaced the voltage regulator (3 times so far) the Cycle Electric instructions specifically said to connect it to the copper (input side) of the main breaker.
Old Today | 03:21 AM
TwiZted Biker
There have been some heated arguments over this very topic in every harley and chopper forum I've been in. And nobody will budge off their way is the right one.
I get to play with this in a few weeks when the current build starts gelling up. Guy wants to us all Moto Gadget electrics and components , CE charging system with the big regulator and a small Antigravity lithium battery I'm tucking into the rear fender so I can hide the electrics in the pocket of a modified horseshoe oil bag. Going to be entertaining seeing how this all will float out.
Old Today | 06:35 AM
Racepres's Avatar
Racepres
Because I am Clumsy, I have accidently grounded the plus side of Battery, by pinching the Regulator lead to battery, putting bike on Lift!!! Dumb, but, Happens...to Me.
Now I run regulators to the (protected/output) side of Main.. if I screw up, it only pops the Breaker!!
Edit; Have Never seen more than the 3 Wires on a Shovel Regulator..Gozinta= AC, 2 wires from Alternaror, Gozoutta= the charging lead to Plus side of Battery..I always trusted the Grounding of the Regulator "body".. for dumping excess!!
jj14x
2018+ Softail Models
Feb 12, 2021 08:31 PM
Taylor68
Ironhead
Aug 13, 2013 05:24 AM
probatebob
Feb 7, 2012 06:40 PM
burchis
Jul 18, 2009 06:44 PM
chazreid
Ironhead
Jul 7, 2006 01:52 AM
