Code P1511 how to erase Fatboy 2016
Old Yesterday | 01:29 PM
evo1958's Avatar
evo1958
2nd Gear
Default Code P1511 how to erase Fatboy 2016
Hi all , for unknow reasons came the code P1511 , the bike doesnt work , someone can help me
how to erase
thanks in advance
Old Yesterday | 01:53 PM
GalvTexGuy's Avatar
GalvTexGuy
Erasing the code will not fix the problem. You need to explain what happened.
  • Enter Diagnostic Mode: Press and hold the Odometer Reset Button (located on the left side of your fuel tank console). While holding the button, turn the ignition switch to the IGNITION position.
  • Wait for "DIAG": Continue holding the button until the odometer screen displays "DIAG" and the speedometer needle sweeps across the gauge. Once "DIAG" appears, release the button.
  • Cycle Through Modules: Press and release the reset button to cycle through the different computer modules. The display will show the following letter codes:
    • P = ECM (Engine Control Module)
    • B = BCM (Body Control Module)
    • SP = Speedometer
    • T = Tachometer
    • U = COM (Communications)
    • ABS = Anti-lock Braking System
  • View Codes: When a module flashes a "Y" (Yes), it means there are active or historical trouble codes stored. To read the exact code, navigate to that module and press and hold the reset button.
  • Scroll: Press and release the button again to scroll through multiple codes or reach the end of the list. Once all codes have been viewed, it will display "END".
  • Clear Codes: If you want to clear a code, navigate to the specific code, press and hold the reset button until "CLEAR" appears, and hold it once more.
Old Yesterday | 02:24 PM
evo1958's Avatar
evo1958
2nd Gear
[QUOTE=GalvTexGuy;22294845]Erasing the code will not fix the problem. You need to explain what happened.
    • SP = Speedometer
    • T = Tachometer
I did all theses stops
i only changed the battery
this code P1511 its about acelerator by wire
Old Yesterday | 02:33 PM
Rounders's Avatar
Rounders
Codes will clear on their own, after the problem is gone. You have to ride maybe 50 miles similar to a car
Old Yesterday | 02:37 PM
CoolBreeze3646's Avatar
CoolBreeze3646
He needs to find the problem first.
Hi all , for unknown reasons came the code P1511 , the bike doesnt work , someone can help me
how to erase thanks in advance
P1511 EFI Power Management Mode
Check your connections if you unplugged anything when changing the battery (ECM connections?).
NOTE:
The above information, while credible, is worth what you paid for it and should not be considered gospel.
Do due diligence, research and have a H-D Field Service Manual before working on your bike.
You will probably have many opinions and suggestions presented; make sure you research the person providing the helpful information as there are some who provide good information that is useful and some who speak out of other orifices with gibberish. You will figure out this quickly.
Dilligafo
Engine Mechanical Topics
May 10, 2024 06:24 PM
Kaye Ball
Jun 6, 2019 07:08 PM
Merkel
Jun 12, 2012 03:22 PM
catdozer
May 27, 2012 09:08 PM
raaaaaa
Oct 7, 2007 12:27 AM
