Frame Protectors Soft tail
Old Oct 25, 2014 | 12:05 PM
thomasf59's Avatar
thomasf59
Default Frame Protectors Soft tail
Bought the Harley frame protectors 94675-99, those of you that are using them did you cut them so to clear the cross member or cut a notch in the protector to fit around the cross member?
Old Oct 25, 2014 | 01:08 PM
Hollywood Ball's Avatar
Hollywood Ball
Had them when I had my Night Train, and yes, I trimmed a spot out for the crossmember.
Old Oct 25, 2014 | 01:16 PM
Bluraven's Avatar
Bluraven
Thanks for mentioning this Thomas.
I was looking to find something to do this afternoon so I might just head over to Lowes and see what I get get to custom build my own.
BTW, where did you get yours and did you have to order them?
Old Oct 25, 2014 | 01:22 PM
thomasf59's Avatar
thomasf59
I found the directions I cut them, first cut on both 5 1/4 inches works perfect on both sides, side stand on a block about 2 inches thick, rubber pads removed from Red jack, looks like it will slide under will out any problem will find out when I have some help on the first lift try.
Old Oct 25, 2014 | 02:57 PM
thomasf59's Avatar
thomasf59
Bluraven
Had to order them from Holistens normally a stock item they were out, took 4 days to get them.I though about trying to make something that would work, these fit the frame can't put them on wrong once there cut.Once I figure out the balance point I'll mark them and no guessing from there on out. Just a matter of deciding on how to tie the bike to the jack from there.
Old Oct 25, 2014 | 04:23 PM
cocky's Avatar
cocky
I used an idea I read here. Heater hose slit longwise. 1 inch inside diameter and Its 3/8 thick and thats thick enough that the jack doesnt touch the shocks. Advanced auto, $3.18.
Old Oct 25, 2014 | 04:35 PM
Bluraven's Avatar
Bluraven
Great minds must think alike.
The only difference is I used 3/4" hose and I got my hose from Auto Zone.
Works great and just gets the jack off the shocks.
Attached Thumbnails Frame Protectors Soft tail-sears-yellow-jack-with-progressive-shocks.jpg   Frame Protectors Soft tail-sears-yellow-jack.jpg
Old Oct 25, 2014 | 04:55 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Default sweet
I learned something new today. now I can have some fun. Thanx..........
Old Oct 27, 2014 | 11:59 AM
SUUIE's Avatar
SUUIE
The heater hose is a great cheap way to protect but, I have to wonder if they offer the same stability that the frame protectors, which aren't that expensive, offer.
Old Oct 27, 2014 | 02:09 PM
Bluraven's Avatar
Bluraven
After putting the hose on I found the stability no different than when the jack was directly on the frame.
That being said, I don't see anything wrong with the frame protectors and for $25 it ain't going to break the bank.
