Added some lights to the bike
Old Oct 28, 2014 | 06:54 AM
Superfly3176's Avatar
Superfly3176
Default Added some lights to the bike
Added a trucklite 7" led light and rear led turn signals. Really wanted to give some input on the installs and use.
Trucklite LED
Led headlight priced @ 170. Obvious improvement over stock for night time use. The light is a very bright white.
Just couldnt see me buying a daymaker for $230 more especially when i need to buy two running lights as well.
The install was extremely simple plug and play. If you cant do it you should reconsider doing any work on a bike it was literally take screws out, unplug old light, plug new one back in.
I'd give the light an 8/10 and only because there's some hashtag pattern, but nothing major.
Custom dynamics Led turn signal/running/brake light.
I opted for the combo on the turn signals mostly due to my moms bitching about how people cant see me.
The install for just the turn signal would be just dropping a light in. This is different you need to tap into lines and i also didnt find a way to do this without drilling a hole in my light housing.
I will recommend looking at it now that you get some kind of wire wrap. The wires that you use to tap seem thin and wont hold up to much rubbing/bouncing around.
The install was easy enough the positap connectors work well. What i will say about them is put them as far away from the connectors as possible.
The most confusing part was tapping into the right wires. The wiring diagram wasnt that easy to read it went from 7 to 7 to 6 wires. I guess thats correct with how they were but was a little confusing at first.
Overall the turn signal/running/brakr lights are very bright and im impressed. I feel though they should have expanded so the board wraps entirely around the screw holes in the turn signals seemed dumb not to.
Id give these an 8/10 as well.
Old Oct 28, 2014 | 02:21 PM
amkaos's Avatar
amkaos
This its the same setup that I'm doing when the phase 7 comes in this week..not real happy that we have to add trim rings..oh well..
Did you re aim?
Old Oct 29, 2014 | 09:49 AM
Superfly3176
Did you re aim?
Honestly I didn't have to. Im not thrilled about the trim rings either. Rather unfortunate. But still better then the cost from harley.
Old Oct 30, 2014 | 09:14 PM
Mathis's Avatar
Mathis
Which ring did you have to buy (part number?)?
Old Oct 31, 2014 | 09:02 AM
amkaos's Avatar
amkaos
i installed mine.. it does not stick out but there is a gap all around between the exiting trim ring and the new lite.. i dont know what will fill in the gap.. maybe a ghost ring is all i could guess
trnewman
Mar 17, 2013 10:43 AM
trnewman
Mar 16, 2013 07:02 PM
Dean L
Dec 31, 2012 02:36 PM
hattitude
Dec 27, 2012 08:31 AM
gnormous
Jul 9, 2012 11:28 AM
