Tool advice
Old Dec 5, 2014 | 04:16 PM
  #41
Dieselvol's Avatar
Dieselvol
Originally Posted by Alain
Oh boy. You might be in trouble there. That loctite will probably cause the same problem you were having before but now in the opposite direction.
Maybe a little heat on that bolt if that's the case will help.
Well, that didn't work. I called Progressive. They say take the fork back off of the bike, compress the fork as much as possible, and that should hold it in place and allow for proper torquing. I'll get on that tonight and update later. Not looking forward to wrestling the tins off again.
Old Dec 5, 2014 | 06:22 PM
  #42
1004ron's Avatar
1004ron
That's right.
Originally Posted by 1004ron
Is it the screw/bolt with the copper seal - if so, what's happening is the complete Momotube is rotating - what you could try is get some compression on the shocks while trying to tighten that screw.
The screw cant drop out as you say, but it could result in an oil leak.
A PIA, but degreasing the bottoming cup and bottom end of the legs, and Monotube would help it grip in the bottom of the leg.
Old Dec 5, 2014 | 07:19 PM
  #43
Dieselvol's Avatar
Dieselvol
That's right.
No amount of compressing the shock has mattered. I have a rachet strap on it, so tight I can't compress the shock any further with all of my weight. I poked a hole in the strap to allow access to the bolt. The internals still spin freely. Though I doubt it's the answer, should I back the bolt out so as to be certain that the Loctite is not a factor?
Old Dec 5, 2014 | 08:18 PM
  #44
1004ron's Avatar
1004ron
Good point, if the Loctite has set before it reached the correct torque it could cause this, and if so, you'll most likely have a problem taking this screw out.
I had the bottoming cup come loose on one of the shocks - I then took it apart, degreased it and the end of the Monotube, stuck the cup on the end of the Monotube and guided it into the shock.
I used just a little Loctite Blue (Medium) - no ways was I going to use the Red on a small screw like this.
Old Dec 5, 2014 | 08:26 PM
  #45
Dieselvol's Avatar
Dieselvol
Don't think that's what happened. I tightened it right away.
I'm certain I did this as well.
I probably should have done that. I was told to "red" every thing. Progressive seemed to think all would be fixed with the compression. I'm about ready to deploy the monkey wrench. That'll fix it.
Old Dec 5, 2014 | 08:33 PM
  #46
QC's Avatar
QC
It is possible the tapped hole is not tapped deep enough and the bolt is bottoming out in the hole before tightening down on the fork. Without being there, just a WAG.
03dragonRK
Apr 5, 2018 05:43 PM
Northbound Southerner
Dec 23, 2014 01:35 PM
ndnguyd
Feb 18, 2012 12:48 AM
ljrock88
Mar 16, 2010 07:16 AM
davenportm
Jul 10, 2009 10:04 AM
