Handlebar change!!!
Old Dec 24, 2014 | 09:40 PM
Scooter68's Avatar
Scooter68
Default Handlebar change!!!
I am about to buy a set up 10 inch ape hanger bars set on my 07 Deluxe. Anyone do this, and do the work themselves, and how long did it take you? The bars I'm getting also are 1-1/4 inch up from the stock 1 inch, which makes getting new grips that much harder it seems. Any input and help/advise would be appreciated.
Old Dec 24, 2014 | 11:10 PM
Mighty_Mickey's Avatar
Mighty_Mickey
its not difficult, it can be a p.i.t.a. if you're running wires internally.. take your time.. it can be done under an hour.. since its your 1st time probably about 2 hrs.. the grips shouldn't be hard to find the handlebars will reduce to 1 inch at the ends..
Old Dec 25, 2014 | 02:28 AM
perrybell4's Avatar
perrybell4
I just put 10inch mini apes on my deluxe. Used 1 inch risers and ran wires interaly. Had to extend wires but all other stock cables fit. Could use a little longer clutch cable but works fine. Let me know if you have any specific questions.
Old Dec 25, 2014 | 07:37 AM
Scooter68's Avatar
Scooter68
Well Mickey, I am getting a set up all prewired internally,as well as plug and play too. Oh ok, didn't know that on the ends reducing. good I have a set of grips I want too. Perry, the throttle cable, clutch cable and brake lines are all included in this stainless steel too, to the correct length, and I plan on going with 1-1/2 in risers. My biggest question was how hard is it to change the clutch and throttle cables. The clymer manuel shows how, but it's a lot of work.
Old Dec 25, 2014 | 12:15 PM
CajunIron's Avatar
CajunIron
YouTube has a bunch of videos on the subject and it's pretty straight forward. I would also pick up an extra set up those snap rings that hold the clutch lever pivot pin. I've had them become airborne etc. The only ones I've found that work are the HD ones the ones in the hardware stores are too thick.
Old Dec 25, 2014 | 12:19 PM
gnarlyfox001's Avatar
gnarlyfox001
Which company has the pre made wire kits that are plug and play? I am also installing 10" mini apes.
Old Dec 25, 2014 | 12:59 PM
CajunIron's Avatar
CajunIron
http://www.namzcustomcycleproducts.com/products/handlebar_extension_kits_2011.html
http://www.guerrillacables.com/
Harley also makes one believe it's 12 inch only used in conjunction with their 16 inch bars. Part #69200034
http://houseofharley.com/en/products/for-the-bike/handlebars-controls-grips-and-mirrors/69200034__harleydavidson-switch-wire-extension-kit-69200034?gclid=Cj0KEQiAiO-kBRCNxtaJp4-En6sBEiQAnkvW38XoSenYgjQEvGhhWUfAV6Gjc1MapgIEH0V6X QlRK5oaAs8T8P8HAQ#.VJxeLUAIE
Old Jan 5, 2015 | 07:29 PM
Scooter68's Avatar
Scooter68
The company is Hill Country Customs. I just got the package today, and not sure when I'm going to get to start this install.
Old Jan 5, 2015 | 07:30 PM
Scooter68's Avatar
Scooter68
Yes, thanks Cajun for reminding me of those, I have a list of parts I need to get from Harley soon, and that needs to be added to it.
Old Jan 5, 2015 | 08:39 PM
brockND's Avatar
brockND
I have done bar swaps on bikes but I had never done cables until this last spring. many of the dumb mistakes I made you will not experience due to your handle bars already being wired. I do suggest to pay close attention to your throttle cables when hooking them up. I accidentally hooked mine up backwards and for some reason it was a nightmare getting them back out. I also suggest checking out the tips and tricks on draining your tank before removing it. helps to not make a huge mess in the middle of a project. While replacing the clutch cable, I recommend having the right snap ring pliers. Also when you pop that snap ring due it in a Frisbee or a bucket or something because some pieces may come out that you didn't expect. Like I said these may be elementary problems I am talking about but my first time this is what happened to me. Hope you like the apes!
