Backfires on deceleration
Old Jan 27, 2015 | 11:10 AM
baukienvn's Avatar
baukienvn
Stage I
Default Backfires on deceleration
My Harley Davidson heritage softail has an annoying backfire from the rear cylinder when I let off the throttle on the freeway or when I'm coming to a light. I just had the top end rebuilt completely rings valves heads refaced etc plugs are new exhaust system is tight no leaks. Now the bike is only 4 years old but I do have 99k on the motor.. Any ideas??
Old Jan 27, 2015 | 11:45 AM
upflying's Avatar
upflying
Wow, a Vietnam Harley. Welcome to the forum!
Maybe a mod can move your post to the appropriate discussion room, "off topic" is not correct.
Old Jan 27, 2015 | 11:53 AM
RAWHIDE07's Avatar
RAWHIDE07
Possible intake manifold leak.
Old Jan 27, 2015 | 12:05 PM
Hippie49's Avatar
Hippie49
Would be the first place I would look.
Mine was doing the same.
Applied some thread locker and torqued to spec. and all is well.
Old Jan 27, 2015 | 04:48 PM
hollowpoint's Avatar
hollowpoint
You better take it to an authorized Harley Davidson Dealer.
Old Jan 27, 2015 | 04:53 PM
Gliden's Avatar
Gliden
After all that work....give it to a tuner and tune it out and maximize all the work you had done. I had annoying decel pop after 106 job was done. I pin pointed what Rpm's on decel and what speeds it happened at, told my builder/tuner....he dialed it out.
Once in a while I get a pop or two but not like the machine gun popping I had after the build.
Old Jan 27, 2015 | 06:01 PM
splattttttt's Avatar
splattttttt
Unburned fuel. Probably running too rich.
Old Jan 27, 2015 | 06:07 PM
UT-rckr's Avatar
UT-rckr
Common problem when changing exhaust/intake/etc. Air/fuel ratio needs to be adjusted, which can be done in a number of ways (dyno and tune, flash tuner, etc.)
Old Jan 27, 2015 | 06:16 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Take it to a reputable tuner.
AK83
Shovelhead
11
Jan 9, 2020 12:08 AM
cklapd
Engine Mechanical Topics
Jun 20, 2018 02:59 PM
TonyRayG76Iron
Ironhead
34
May 25, 2015 10:34 AM
sanmanbob
Ironhead
18
Jun 6, 2010 03:11 PM
ddsglide
Aug 16, 2009 09:28 PM
