Mock Up For New Bars on Blackline
Old Jan 27, 2015 | 05:31 PM
Gibler77's Avatar
Gibler77
Default Mock Up For New Bars on Blackline
I bought new bars for the Blackline, but I now need to mock them up so I can measure for cables. With the bars being internally wired, is it necessary to remove the tank and disconnect the harnesses, or can I disconnect at the controls? I don't want to get too far into the process if the bars don't suit me.
Old Jan 27, 2015 | 06:41 PM
Blackp5ca's Avatar
Blackp5ca
I just swapped out the bars on my Blackline, just take out the the tank bolts and slide it back a few inches, you'll have to unclip the fuel line (just push up the collar and it unclips) there is a bolt under the console bar and shield if you haven't taken it off before. The controls connector plugs are right there..they fit through the holes in the bars for the internal wiring so no need to take connectors apart. It's actually a pretty easy job. Make sure you thread lock those new bars and crank the nuts tight.
Old Jan 31, 2015 | 05:18 PM
Gibler77's Avatar
Gibler77
How difficult was it to break loose the bolts on the stock bars? I'm never the smallest or weakest guy at the bar, but I"m having a hell of a time getting these things to move. Any tips?
Old Feb 1, 2015 | 02:48 AM
goats's Avatar
goats
secure the bike and grab a cheater bar. they will loosen.
Old Feb 1, 2015 | 02:46 PM
Gibler77's Avatar
Gibler77
Got the bars loose, but I'm going to hold off on trying to install the new ones myself. Will either set money aside until I can afford to have the dealership install them, or I'll find someone local who doesn't mind helping for a few bucks. This will also give me time to order cables and any necessary extras without feeling like I'm being rushed because the bike is torn apart.
SPCJ
Dec 17, 2015 06:22 AM
MSKelly65
Jan 4, 2012 03:09 PM
Biffmaster2000
Nov 22, 2009 08:05 PM
freebyrd
Sep 1, 2008 11:49 PM
hk_shooter
Oct 17, 2007 06:22 PM
