Changing bars
Old Oct 17, 2007 | 12:31 PM
hk_shooter's Avatar
hk_shooter
Default Changing bars
No, I didn't get kicked out of my favorite watering hole.Handle bars. Gonna change my bars out. 06 Bob, going to save height bars, just black. Any tricks, ie; installing controls onto bars then bars onto bike? Or mount bars then controls? Is the left hand grip glued on, or held on by the switch housing like right side.
Seems simple enough, but, I have this fantastic data base of knowledge, so I might as well tap into it. Thanks in advance.
Old Oct 17, 2007 | 12:42 PM
js1268's Avatar
js1268
Default RE: Changing bars
hey hk,
won't be much of a problem for you at all considering i'm assuming you won't be running internals?....yes, left grip is glued on.... will most likely have to damage it to remove it... get new grips...that said, the only real tricky thing is the accel/decel cables.... just give them some slack before you remove them from the right grip...and don't lose the brass ferrels on the ends ....also, you'll probably need new retainers that hold your wiring against the handlebars.... although if you're careful removing them, you can reuse them
...oh, and if you aren't running internals, you should be able to just remove everything and drape it all over your tank (cover it first, obviously)....install your bars, then reinstall everything
Old Oct 17, 2007 | 12:58 PM
hk_shooter's Avatar
hk_shooter
Yep, sorry forgot to mention, no internals.
Old Oct 17, 2007 | 01:24 PM
SPECIAL ED's Avatar
SPECIAL ED
Stick a screw driver in between the bar and the grip, pry it out a little, shoot some WD40 in there work it back and forth a bit.It'll pop right off after that, if it doesn't repeat.
Old Oct 17, 2007 | 02:35 PM
bikerdog134's Avatar
bikerdog134
just loosen the screws on the controls and slid em off . if you opt to remove everything squeese your brake lever and put a piece of cardboard for a spacer so you dont damage your brake light switch. put a towel on the floor in case you drop the brass furrels. makes them easier to find. good luck its not a very tough project take your time and you should have no problem
Old Oct 17, 2007 | 02:53 PM
pwer pla's Avatar
pwer pla
Quick tip from someone who made a big mistake. When working with the controls PROTECT THE GAS TANK. I was adjusting my brake clamp and dropped the bracket on the tank causing two nice sized paint chips on the tank of my new 07 WD. Had about 1500 miles when I did it. Hope this advice saves your paint.
Old Oct 17, 2007 | 05:37 PM
js1268's Avatar
js1268
yes, indeed....forgot to mention the cardboard in the brake lever!.... don't forget to do that..... and yes, like Special Ed insinuates- you're gonna wrestle with that left grip....which is simply why i stated to spend the 60 bucks and get a nice new pair with chrome ends ...but if you do intend on keeping both grips, and are able to remove the left one, you don't need to remove the accel and decel cables from the right grip... you can keep all those components together and slide them off the handlebar
good luck... take your time.... keep us posted
Old Oct 17, 2007 | 05:51 PM
hk_shooter's Avatar
hk_shooter
Thank You all. So the cardboard is a must do, correct? I pull back the clutch a little bit and put the cardboard between the lever and the other part?
Old Oct 17, 2007 | 06:10 PM
Trotter's Avatar
Trotter
Right side Brake Lever = Cardboard ..... Clutch is Ok and a long thin screw driver and WD40 and the grip will slide right off like Ed said no need for grips unless you want them
Old Oct 17, 2007 | 06:22 PM
hk_shooter's Avatar
hk_shooter
ORIGINAL: Trotter
Gotcha Trotter. Brake lever. A little typing dyslexia. I was thinking right hand... That's to keep the brake switch from malfunctioning?
Parrothead 1977
Sep 21, 2018 07:43 AM
SPCJ
Dec 17, 2015 06:22 AM
WVICEMAN
EVO
Oct 29, 2015 06:31 PM
Gibler77
Feb 1, 2015 02:46 PM
bucs012
Mar 25, 2008 11:51 AM
