how do i adjust my handle bars forward
Old Sep 1, 2008 | 09:28 PM
freebyrd's Avatar
freebyrd
Default how do i adjust my handle bars forward
its an 07 streetbob do i just loosen up the four allen head screws on the triple tress and push? that easy?
freebyrd
Old Sep 1, 2008 | 09:30 PM
Badmonkey's Avatar
Badmonkey
yes...
Old Sep 1, 2008 | 09:31 PM
xmarine's Avatar
xmarine
Yep that easy. But don't loosen them all, keep one on the snug side or the bars will drop onto the tank. Don't ask me how I know!
xmarine
Old Sep 1, 2008 | 09:41 PM
Jimbo60's Avatar
Jimbo60
I just loosen the two at the top (toward the front of the bike) just enough that a gentle push will move the bars.
What ever you do, dont think "all four" by the time you start to loosen #3 is when the 'flop' occurs.
Don't ask me either
................ Jim
Old Sep 1, 2008 | 10:38 PM
rounder's Avatar
rounder
there is a sequence to retighten.... after repositioning the bars tighten town the rear bolts till the clamps in the rear are touching... then you tighten the front ones to 12-15 ft-lbs...finally tighten the rear to 12-15 ft-lbs... make sure the front ones are loose enough for the rear clamps to touch.
Old Sep 1, 2008 | 11:49 PM
BluBob's Avatar
BluBob
COVER YOUR TANK with a thick blanket or something that will absorb the impact if you drop those bars onto it. If they come down they can do some major cosmetic damage to your paint and even dent the tank when the switch housings hit.
Also, I disagree with one point, the riser clamp should not touch the risers at the front or the rear. My manual calls for tightening the rear snug, then torquing the front, then torquing the rear, but not tightening either down until they close the 'gap'.
Parrothead 1977
Sep 21, 2018 07:43 AM
SPCJ
Dec 17, 2015 06:22 AM
WVICEMAN
EVO
Oct 29, 2015 06:31 PM
Gibler77
Feb 1, 2015 02:46 PM
Odis01
Sep 23, 2011 04:26 PM
