Lower Front End Too???
Old Feb 15, 2015 | 04:44 PM
Mike NY's Avatar
Mike NY
Default Lower Front End Too???
I'm considering adding Shotgun Shocks so I figure as long as I am at it during the Winter I would upgrade the Front End with some Progressive Monotubes. Does it make sense to go with the Lowering version? 1"-2".
Ground clearance is not an issue for me as far of flat footing (I'm 6'1") so it would be more for appearance but I want to be sure Im not sacrificing ride stability or comfort.
Old Feb 15, 2015 | 06:01 PM
Pudge211's Avatar
Pudge211
I lowered the front of mine 2" the same time I installed the SS shock. I'm 6' tall and have noticed no handling issues, but the front is a lot stiffer riding. By a looks stand point it looks better slammed with a 2" drop in the front also.
Old Feb 16, 2015 | 06:19 PM
Mike NY's Avatar
Mike NY
Thanks, I kinda of thought that would be the case. After searching and reading a ton of threads it looks like I need to shorten my kickstand too. It's like a domino effect but I guess in the end it's worth it..
Mike
Old Feb 16, 2015 | 06:42 PM
bullast's Avatar
bullast
It'll prob look great on that bike.
Down side is it'll turn in a little bit slower but thats negligible.
Depending what you weigh, it'll prob make a tremendous difference in the ride.
Properly sprung suspension is a game changer.
Old Feb 17, 2015 | 05:16 PM
Pudge211's Avatar
Pudge211
Mike
I have no issue with the stock jiffy stand. You will have to watch which way you park on inclines whether you get a shorter stAnd or not.
Old Feb 17, 2015 | 07:10 PM
kozy22's Avatar
kozy22
I didn't lower mine, so you don't have too. It does look better though.
Also think about adding some Ricor Intimidators
Old Feb 18, 2015 | 10:50 AM
Mike NY's Avatar
Mike NY
So are the Ricor Intimidators in addition to changing the suspension to Monotubes or instead of?
Is that a whole other debate?
Mike
Old Feb 18, 2015 | 12:28 PM
Village Idiot™'s Avatar
Village Idiot™
I went 2" as well. It's not enough. I'm going to go another 2" when I get the new wheel, but it will end up being 3" lower over all with the wheel size change.
Old Feb 18, 2015 | 12:38 PM
Echo6 Sierra's Avatar
Echo6 Sierra
Why is the 2" not enough? I think I found a shop that will handle lowering the inverted HD forks I have on my bike and help me level her out; just want to make sure I do it right the first time because it's not a simple swap in/out springs for me...
Old Feb 18, 2015 | 07:58 PM
Pudge211's Avatar
Pudge211
If you go any lower than 2" Echo you will end up with about zero rebound in the shocks producing a very stiff ride. I have the heavy fork oil with a 2" drop on the front and it is stiff up front.
