Thankful to be alive
Old Mar 9, 2015 | 06:50 AM
  #51
Warp Factor's Avatar
Warp Factor
Originally Posted by tbonetony06
I'm also interested in this "modulating" headlight? How does it work if your headlight is already on? Does it only modulate when you 1st turn it on? Is there a button you hit to make it modulate? I have similar on my rear brake light and rear blinkers. I got tired of hearing screeching tires coming up behind me when I'm sitting at a red light. I am interested and open to try anything that increases my chances of getting myself and my bike home and in one piece.
Tony, there are various options on how they are set up, but this is generally how it goes with a modulator installed:
With the factory high-low beam switch set to low, the headlight operates normally. When set to high-beam, the headlight flashes continuously during daylight. So you can easily turn the flashing function on and off as you see fit. I generally don't use the flashing function when I'm riding with a group, unless I happen to be at the front.
After dusk, a light sensor automatically changes the operation back to conventional low and high beam operation, with no flashing. This automatic change is required by law.
Installation is plug-and-play, all inside the headlight bucket, with the exception that the light sensor needs to be mounted somewhere outside the headlight housing so it can read the light level. One can drill a hole in the headlight housing and mount the sensor in a supplied grommet, but what most of us do is run the sensor wire outside the housing using an existing hole, and just zip-tie the sensor to the wiring loom somewhere around the top of the trees.
The ones I'm using are the Kisan Pathblazer, about a hundred bucks. Other brands may be better or worse... the Kisan is the only one I happen to have personal experience with.
Old Mar 9, 2015 | 10:33 AM
  #52
super2kc's Avatar
super2kc
Makes my blood boil to read this, more so that he Fu@ked off after slammin into ya. This is why we should carry mini missle launchers, blow that some bitch off the rd from a mile away!!!
Good to hear you didn't get injured too bad though!
Old Mar 9, 2015 | 06:25 PM
  #53
srt8's Avatar
srt8
lol it would be like mad max out there if we had missile launchers
Old Mar 10, 2015 | 11:29 AM
  #54
super2kc's Avatar
super2kc
If someone hit me and took off? I would do everything in my power to get the license plate, hunt'm down and permanently BLIND'em!!! Ensuring they would never be able to do that to another fellow rider again :-)
Old Mar 10, 2015 | 02:48 PM
  #55
Steven725's Avatar
Steven725
I had a close call yesterday and after reading this I am just glad that you are alive man.
Old Mar 10, 2015 | 08:10 PM
  #56
Woffski's Avatar
Woffski
Glad you made out OK....
Old Mar 11, 2015 | 12:24 PM
  #57
jaysnafu's Avatar
jaysnafu
Glad you ae alright man. I would be looking at the lexus dealer/ repair shops to track this guy down. Shouldnt be to hard to find the guy.
Old Mar 14, 2015 | 09:39 PM
  #58
Pete3323's Avatar
Pete3323
Best wishes in your recovery, bro. The hottest place in hell reserved for the ***** that downed you..and ran.
Old Mar 28, 2015 | 03:57 AM
  #59
srt8's Avatar
srt8
pretty close to a happy ending, supposed to pick her up after work today, 14" apes and wiring supposed to be here around Wednesday. Cant wait its already been to long...and she picked up a new nick name while she was at the dealer "Copper Top"
Old Apr 1, 2015 | 10:08 AM
  #60
srt8's Avatar
srt8
She made it home Saturday night, looking like I just rolled it off the show room floor
crabio
Jul 24, 2016 02:25 PM
GetLost☠1982
Oct 2, 2009 10:26 AM
tree88
Dec 25, 2008 04:44 PM
firefighter43
Oct 7, 2005 10:14 AM
