Brake wire splice on a 2014 Heritage Classic
Old Feb 19, 2015 | 06:37 PM
Nelmar's Avatar
Nelmar
Default Brake wire splice on a 2014 Heritage Classic
Hello Fellow Riders:
I have a 2014 HD Heritage Classic. I bought a trunk with tail lights that I want to hook up to existing brake wire. I took it to the local HD dealer that I wanted the trunk lights wired to existing brake wire(s). I was told that they don't "splice or cut."
Based on their less-than-enthusiastic response, I'm entertaining the idea of splicing the brake wire. Any tips or ideas where to splice (or posi-tap) onto bike brake wire? Has anyone spliced or posi-tapped into a 2014 Heritage?
Thanks
Nemar
Old Feb 19, 2015 | 06:50 PM
jam436's Avatar
jam436
It will be one of the wires on the connectors under your seat.
You'll see three there.
Two connectors go to your turns and/or brakes, the center one with only two wires handles the license plate light.
I found out while adding a center brake light under the fender of my Slim.
(This is of course assuming the wiring harnesses are the same across Softails, which I believe they are.)
Here's a thread about it that may help - at least it will help in identifying the connectors (check out the red "blank" shown for the Slim - it doesn't have a dedicated center brake light - this is where you should find your brake light circuit):
https://www.hdforums.com/forum/softa...ight-help.html
..and another with wiring diagrams - sorry I don't have the exact wire color you're looking for though.
https://www.hdforums.com/forum/softa...ring-help.html
Old Feb 19, 2015 | 10:02 PM
onecoolpilot's Avatar
onecoolpilot
Looks like it may be in a 7 pin connector, blue wire is the rear brake light.
VTwinfelipe
Electrical/Lighting/Alarm
Mar 21, 2017 04:30 PM
brntwltrs
Aug 4, 2014 06:21 PM
s.ga.rider
Aug 18, 2011 07:46 PM
cockerhamsg
Sep 26, 2010 04:25 AM
Gregte
May 19, 2008 07:39 PM
