09 fatboy wheel on 06 standard
Old Feb 21, 2015 | 04:27 PM
StuPadasso7428's Avatar
StuPadasso7428
6th Gear
Default 09 fatboy wheel on 06 standard
I'm looking to put a 09 fatboy rear wheel (43596-09) on my 06 standard. Has anyone tried this or know, for sure, if it will work. I know it's the same dimension. And that the axle and bearing are not the same size but those are relatively easy fixes. What about the brake rotor offset? They use different calipers so I wasn't sure if that changed rotor offset.
Old Feb 21, 2015 | 05:21 PM
Pudge211's Avatar
Pudge211
I added an 07 and up wheel to the rear of my 06' train. I had to get a 3/4" bearing kit, shorten the axle spacer on the rotor side and lengthen the belt side by 3/8". Also had to add a 3/8" pulley spacer behind the pulley. Got the bearing kit from HD and the axle and pulley spacers from here http://vulcanworks.net/store/Pulley-...ction=0&page=2
Take measurements from rim to swingarm insides, take measurements from pulley and rotor to swing arm insides on existing wheel. Place new wheel inside swingarm and center on your measurements then do the math for rotor and pulley spacers. I used the same tire so I also measured corner of tire sidewall to inside of fender.
Good Luck.
Old Feb 21, 2015 | 07:53 PM
StuPadasso7428
6th Gear
Great info. Thanks Pudge
Old Mar 11, 2015 | 06:12 PM
StuPadasso7428
6th Gear
It's done. And in case anyone is interested in doing something similar here's some detail on what it took.
I went with the 25mm bearing kit for the 09 wheel.
Ordered reducers from http://vulcanworks.net/store/Wheel-B...mm-to-3-4.html
Got axle spacers from the same place: 1/8" longer on belt side (ordered 1.5")
1/4" shorter on rotor side (ordered 1/4")
1/4" pulley spacer
Slipstrm
Apr 17, 2017 03:46 PM
0734
EVO
Jul 19, 2014 03:00 AM
Pudge211
Jan 1, 2014 08:42 PM
06 flstfise
Mar 12, 2013 02:15 PM
Rick101285
Jan 9, 2010 03:56 PM
