FP3 issue on 2015 Breakout.....
Old Apr 2, 2015 | 05:05 PM
sincitychoppa's Avatar
sincitychoppa
Default FP3 issue on 2015 Breakout.....
I was in the midst of an autotune with my FP3, I was going to go for my 3rd autotune session today to finish up the tune as I changed out my exhaust baffles so I felt it would be a good idea. My bike was running pretty strong after the 2nd riding session of doing an autotune.
However today when I went toe tart my bike it, it almost didn't, then it was running VERY choppy. I figured Id let it warm up and see if that helped once the full ratio leaned out a smidge. Well it didn't get any better and when you'd go to rev the bike, it would just sputter. I then quit the autotune and went back to the base map and uploaded that. Now the bike seems to be running OK. But I am rather concerned as it was running great yestderday and then all of a sudden it didn't. I sure hope I expect better reliability in the future. Any thoughts???
Old Apr 2, 2015 | 05:45 PM
baloot-boy's Avatar
baloot-boy
Maybe I'm wrong, but I would think if you change out your baffles, you would want to start your autotune runs all over again. Wouldn't seem like changing baffles out is a big change in AFR, but that's really the only thing that changed on your third run, so I would guess its directly related.
Old Apr 2, 2015 | 05:57 PM
sincitychoppa
my post was confusing. I did start the autotune AFTER the baffle change out.
Old Apr 2, 2015 | 07:38 PM
FurryOne's Avatar
FurryOne
Originally Posted by sincitychoppa
I was in the midst of an autotune with my FP3, ...
(and then Arrrggghhhh!!)
Ok, so you really didn't say that... I found that even after I got Autotune to work and populate the maps, the end results sucked on my '13, so I ended up going with a canned map, and it's been pretty good since then. V&H won't get off their a$$es and map Bassani (maybe because they're better pipes?) so I'm stuck with what the FP3 has.
Old Apr 2, 2015 | 08:12 PM
sincitychoppa
Actually the autotune has worked well for me in the past. The problem is that it doesn't seem to be consistent. Its like the program doesn't "Stick" in the big. I am not savvy when it comes to programming, but I would think once you upload a MAP it should run the same day in and day out. My bike doesn't for whatever reason.
trike1
The Dyno Room
Aug 3, 2019 06:11 PM
firehawk6
Jul 16, 2019 12:43 PM
kernow
Oct 16, 2018 09:17 AM
Trust
Apr 11, 2017 01:37 PM
Iron6677
Aug 17, 2015 03:58 PM
