Ok, what did I do wrong...
I rode the bike for an hour or so under MANY different conditions, got quite a few boxes to turn green, great. I stopped and hit 'save' and 'finish'. Great, that was easy... Until later I noticed that my phone had a message telling me that the AutoTune was still running, so I went into the app to shut it off.
It shows a MAP called AutoTune generated from #2 saved MAP which is the MAP I loaded this morning. I click on it, the FP3 goes thru it's turn the bike off, turn the bike back on, etc... only there is nothing showing up on the AutoTune screen. It's like it didn't save anything, no orange or green boxes and is apparently starting an AutoTune session from scratch, I know that because I started the bike and and it didn't like taking any throttle at all. I just reflashed with the MAP I loaded this morning before the AutoTune session I ran.
What did I do wrong, appears I didn't actually save the AutoTune session like I thought I did, or is it something else?
If it runs the same you didnt get it done successfully.
If it runs worse check to be sure your rear o2 sensor (black connector) is in the rear pipe and visa versa.
If it runs better...repeat your autotune session.
Bob
It was pretty bright out today and a little hard to see the phone's screen so maybe I didn't correctly save the AutoTune session.
It did show that there was an autotune MAP based on the Rush muffler MAP. But as I said, it was blank when I went back to it so, looks like no hitting the lightening bolt icon is the problem.
So hitting the lightening bolt icon is first, then the save/finish?
I appreciate your input. Thanks!
That would explain why my phone was showing an icon saying the auto tune session was still ongoing. I downloaded the user manual for the FP3, and no where does it mention hitting the lightening bolt when wanting to save an auto tune session.
So apparently I was ok with what I did when I hit 'apply' earlier today. Where I screwed up I guess was when I tried to get rid of the icon off my phone and was concerned none of the orange and green cells were showing up. I'm back to the Rush muffler MAP, and will do another auto tune session.
Here's a link to the thread on Streetglide.com if anyone is interested.
https://streetglide.com/showthread.p...cess-Explained
The two columns of orange sounds like a software bug tbh. I would recommend exiting the app with a force close procedure to ensure it's all the way shut down, then taking another look at the data once the app is reopened.
Bryan
Bryan
