Need help w/high speed wobble on 2007 NT
Old Apr 7, 2015 | 12:17 PM
Warp Factor's Avatar
Warp Factor
When did it start doing it?
Have you tried it without that front fender? Aftermarket fenders can do some strange things aerodynamically.
Old Apr 7, 2015 | 12:38 PM
Echo6 Sierra's Avatar
Echo6 Sierra
Originally Posted by LA_Dog
BTW it's not a stretch to get an occasional bad tire or have hidden damage inside a tire. Thinking back I had something similar with an R1 sport bike, the front tire had an internal break in the sidewall bead belting that was causing wobble at speed. the damage was only evident from looking at the inside of tire. the outside of tire appeared normal.
Thanks. It's actually been doing this since last season, and since then I changed tires from Dunlop to Metzeler front & rear, so I'm pretty sure that's not it.
I first noticed it after changing to apes, however I did that over the winter the first year I had the bike and had never gotten the thing up to 85-90 with drag bars. I bought the bike from a friend, and he reports never having that issue with the drags on it.
No, I've never taken the fender off. I never thought of that, but it's worth a shot.
Old Apr 7, 2015 | 01:40 PM
LA_Dog's Avatar
LA_Dog
serious head scratcher- have you tried a test run with the other wheel yet?
Old Apr 7, 2015 | 02:55 PM
Echo6 Sierra
Not yet; my buddy thinks he has one he's going to dig out for me.
Old Apr 7, 2015 | 03:19 PM
CajunIron's Avatar
CajunIron
I have 16's on my Slim and get it at 80+ speeds. I pushed both hands forward to take the added pressure off the grips and the wobble goes away. Same thing happened when I put apes on my Iron.
Old Apr 7, 2015 | 04:23 PM
Warp Factor
Could be. You never see race bikes with apes, and rarely anything seriously fast.
Old Apr 7, 2015 | 04:53 PM
Echo6 Sierra
You think I should roll my bars forward more??? Where they are right now gives me a good riding position.
Old Apr 7, 2015 | 04:57 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Out of the blue I'd guess rim issues, balance issues, or a bad tire. Be interesting what you find, good luck with that.
Old Apr 7, 2015 | 05:19 PM
professorzoogy's Avatar
professorzoogy
definitely worth checking your front and rear wheel alignment (parallelism) . swingarm bearings ? . measure from center of swingarm axle to center of rear wheel axle for positive alignment . don't rely on just the rear adjusters . out of line wheels can cause weaving and high speed instability or wobble.
Old Apr 8, 2015 | 12:08 AM
PTSDBob's Avatar
PTSDBob
drop that front tire pressure to 30… and give it a go. Tires like to 'expand in circumference' when increasing in speed… your front tire is doing this and as speed increases, so does your tire diameter. If you lower the pressure a bit, you should be able to get to a greater speed before encountering the wobble.
I run mine 30/40 ...
