RevTech DFO
Old Sep 16, 2005 | 10:06 PM
LUV2RIDE's Avatar
LUV2RIDE
Default RevTech DFO
Has anyone have an opinon on these vs. PC
http://www.bikernet.com/garage/revTech.asp
Old Sep 16, 2005 | 10:10 PM
HDF Tech's Avatar
HDF Tech
Default RE: RevTech DFO
Easier set up than the PC, adds just fuel, can't adjust timing, requires less initial work to set. No computer needed for setup. They work well. TFI/DFO = same thing both made by techlusion.
Take a look here http://www.shopsprite.net/~easternp/...roducts_id=103
More info here https://www.hdforums.com/m_67296/tm.htm
Old Sep 16, 2005 | 10:50 PM
Taildraggerdave's Avatar
Taildraggerdave
I have the Revtech Stealth DFO. Also, they are now plug and play. You don't have to splice wires anymore. Simply remove each injector harness and plug into the DFO harness, then plug the DFO harness leads into the injectors. Hook up the ground wire and start tuning. Very simple. The best part is that they are transpartent to the ECM. That way, there will never be a record of having it on your bike, as far as the ECM is concerned. That should eliminate any warranty issues down the road. If the bike breaks, take the DFO off and go to the dealer with a stock bike....
I really like mine. Also, the DFO is cheaper by about 75.00 but is identical to the original TFI.
Daddywags
Electrical/Lighting/Alarm
Sep 30, 2018 09:09 AM
pdevore
Feb 21, 2016 06:51 PM
bbqbrisket
Sep 15, 2012 10:30 AM
LilBudyWizer
Aug 20, 2008 04:41 AM
Halfbuck
Feb 13, 2006 03:33 AM
