FatBoy front wheel install
Old Jun 12, 2015 | 05:57 PM
68_340_Cuda's Avatar
68_340_Cuda
Default FatBoy front wheel install
I've just got a new front tire installed and I'm in the process of reinstalling the front wheel on my 2012 FatBoy. I have a question regarding the right side slider, does it go tight to the spacer on the axle or does it go tight to the outside (7/16" drill bit in axle)
Thanks in advance.
Old Jun 13, 2015 | 04:26 PM
robzuc97's Avatar
robzuc97
I am not sure I am understanding the question but unless the service manual says differently ( I do not have a bike with the new "hollow" axles) then the 7/16" hole should be level to the ground and the hole edge flush with the flat on the outside of the fork (you can use a drill bit to gauge it but I eye it myself!) and the axle TORQUED to the proper number to achieve bearing preload. Any grooves or markings on the spacers should be toward to outside of the wheel.
Old Jun 14, 2015 | 07:40 PM
68_340_Cuda
To bring the slider edge flush to the 7/16 hole I'd have to pull the sliders apart. If I just torque it where it sits there's a gap between those 2 points.
Old Jun 15, 2015 | 02:11 PM
Misbehaven's Avatar
Misbehaven
Nothing in the service manual states to align to the 7/16 hole. Install your axle and spacers torque to 60-65 ft lbs then tighten fork caps s to 132 to 180 inch lbs. No mention of aligning slider with 7/16 hole. BTW the gap between my front hub and slider on the left side is about 1/8 or less of and inch.
Whodattom
Wheels/Tires
Mar 11, 2014 05:53 PM
Dizzy810
Nov 8, 2013 02:09 PM
booze hound
Jul 14, 2013 10:10 PM
steamfitter
Wheels/Tires
14
Apr 15, 2009 11:16 PM
CiSmAXz
Jan 2, 2007 09:26 PM
