Running the Stebel on my RK with the plug and play harness from Amazon. It is very easy to install and MUCH louder than the stock horn. It'll really wake up those 4 wheeled lane drifters!
so your horn is under the black shield.. what about the steibel nautilus?..
it is rated much louder
the harness is like 20$
im not sure what im looking at how to mount the thing.
The horn is the chrome thing in the picture mounted where most softail horns are mounted. Fits right on there using the factory mount. If you need a mount picture let me know I'll take one. The heritage springer has the horn on the fork so I had to buy a mount where the normal harley cowbell is mounted. If you have the cowbell then you already have the mount.
No need to unbolt the tank as I wrote.
The wiring harness is $3.59. I had the inline fuse holder, but it's another couple of bucks if you don't. You don't need this wiring harness, you can easily make your own with crimp connectors, but this makes it a nice install. I was able to tuck my relay down by my battery out of the way.
Tonight's project was to install my Steibel Air horn and wire my passing lights to the Aux fuse so that they stay on with the high beam. Factory wiring feeds the passing lights from the low beam so they go off when on high beam.
I'd planned on pulling the tank but realized I could unbolt the tank from both bolts and hold it up with a bungee cord from the rear mount to the mirror to get to everything. That saved cutting the crossover hose and getting gas everywhere so that was nice. But, I'd prepared for that and bought a brass sharkbite hose splice from Home Depot - I'd planned on pinching the line on both sides with needle nose vice grips, cutting the line and taking the tank off, then, install the splice and two new hose clamps so that I could take the tank on and off in the future without draining it. The vice grips do a great job pinching off the line and with the splice I could lose only a tiny bit of gas when removing the tank in the future.
I purchased a regular softail top motor mount from eBay which has the horn mount. The factory horn mount fits the Steibel air horn perfectly - the Steibel is made to grab the factory nut and as you rotate the air horn it tightens up nicely to the rubber bushing. I ran my Road King like this for many miles.
On the Springer you can remove the factory horn power wire (I left the factory horn in place of course for looks) and run it back to the softail horn location (feeding it back through the fork) with no problems...I did cut the end off the wire and re-attached it to save from having to remove my windshield mount as the terminal wouldn't fit through the windshield mount. The Steibel air horn uses the factory hot terminal and I made a ground wire to the motor mount.
While I was at it, I tapped the fender light wire (orange w/ white stripe) and fed the passing light power switch from this wire. Now my passing lights work on high beam. The fender light circuit has a plug on the left side at the front of the tank and that's where I tapped it, the factory passing lights get their feed from a yellow wire from the headlight right there so it was easy to unhook the factory yellow power wire from the low beam and run a new wire to the orange and white fender light wire (which is fed from the Aux circuit so now my passing lights work on the Accessory position on the ignition switch too if I want.
This thing pegs my decibel meter at 110. It didn't seem any louder with the relay, but, I blew a couple of accessory fuses blowing it so I realized it was drawing a lot of power and I didn't trust those little wires in the handlebars and the horn switch to handle that load. Keep in mind I ran my passing lights on the same fuse as the horn so that fuse had a heavier load than stock. The relay is easy to run and is the right way to do it.
I tried jumping it with much heavier wires, and it was about the same.
As I mentioned, it's a much more attention-getting sound (seems louder), but measured about the same with a decibel meter.
Using heavier wires is not going to make it any louder. A relay puts more power to the horn.
They will both do the same thing, as far as loudness and power go. A relay diverts the battery power through heavier wiring and switches, so there's less of a voltage drop under high current draw. It's not like the relay itself adds power or anything like that.
I don't think I could love it any more or I'd need Supreme Court permission.
The horn on my bike is the Steibel Nautilus. I just call it a Steibel. It's the same as the Wolo Bad Boy and some vendors have other names for it but it's the same horn.
These things are loud - I think most sources list them at around 118dB...
John
I would say 118 dB is loud for horns of that size. My dual tone air horn has a measured volume of 130 dB at 10 feet. I'm disappointed because it was advertised at 139 dB .
I'm pretty sure Harley upgraded their own horns with the release of the rushmore bikes. So just buying a new 14-up stock replacement horn might be a huge improvement over that 20+ year old unit.
Yes! I just bought the latest model HD horn. I still have the OEM one from my 2012. Tested them both...and the new one is much louder.
