Key in ignition???
Old Sep 6, 2015 | 02:42 PM
MarkFXSTC's Avatar
MarkFXSTC
Default Key in ignition???
I'm selling a chrome cover for the key operated grenade coil fitted to a Rocker. Does anyone know which other softail's have the same type of coil? Blackline or Slim maybe? It was supposed to fit a Breakout but it doesn't as it has a finger switch.
Thanks
Old Sep 6, 2015 | 03:24 PM
TpaGreenHornet's Avatar
TpaGreenHornet
Blackline is the same as a breakout. Not sure if you know. There is only a set screw that keeps the finger switch on the coil. maybe you can take it off to fit your cover and reinstall it? if you do make sure you put blue locktite on the set screw. The dealer had to replace mine when it fell off going down the road
Old Sep 6, 2015 | 07:29 PM
MarkFXSTC's Avatar
MarkFXSTC
Thanks for that. I took the finger switch off mine and it still wouldn't fit. I guess it's a rocker only part then.
j33ptj
Oct 5, 2019 03:27 PM
MarkFXSTC
Aug 28, 2015 10:54 AM
boysonch
Sep 9, 2012 07:12 PM
UT-rckr
Jul 21, 2011 08:43 PM
RockerBob
Nov 4, 2010 12:12 AM
