Rough ride and lost horsepower
Old Sep 18, 2015 | 01:19 AM
AzJoe81's Avatar
AzJoe81
Stage II
Default Rough ride and lost horsepower
Hey guys I was on a ride out of state when my 2006 FLSTI started to backfire and ride really rough. It smooths out when I get above 60 but she had no power. It felt like I was pulling a trailer. We checked the plugs and they were fine. I was hoping it was the cables but was wondering what you all thought. Could it be fuel pump? and if so how can I check it?
Old Sep 18, 2015 | 02:05 PM
mopardave's Avatar
mopardave
Bad gas, maybe? Had you recently refueled when it started?
Old Sep 18, 2015 | 03:05 PM
AzJoe81's Avatar
AzJoe81
Stage II
I had, but I've gone through 4 tanks since then too. Changing just the filter should fix it then, right?
Old Sep 18, 2015 | 03:31 PM
dfwhockey17's Avatar
dfwhockey17
Where did you go? Elevation? How is your bike tuned? How do you turn your bike off? Does this happen only when the bike is hot? Fuel pressure regulators and internal hoses are known to crack and fail, to check you need to pull the dash and open the fuel pump plate...
Old Sep 18, 2015 | 04:49 PM
olongapo1's Avatar
olongapo1
Your symptoms sound like what I experienced last year. After many hours of troubleshooting I discovered a failed O-ring on the fuel pressure regulator.
Old Sep 18, 2015 | 08:15 PM
HDmikie's Avatar
HDmikie
Me thinks it's inside your tank. Probably the fuel line is cracked or the regulator near the filter has separated. Might as well replace the filter while in there. JMO
mortensenbt
May 7, 2019 08:24 AM
Kate58
15
Dec 24, 2017 02:31 PM
Bobby Anders
Touring Model Pictures
Jun 17, 2017 11:15 AM
YellowHawk
Feb 18, 2013 07:25 PM
cuffnup
Oct 16, 2011 05:19 PM
