Engine Noise
Old May 5, 2007 | 07:31 PM
bruhan's Avatar
bruhan
Stage II
Default Engine Noise
I am seeking others experience about engine noise on 2006 softails. The engine sounds like the pistons are slapping at two different engine speeds. The dealer tells me this is normal; and is due to emission requirements forcing theengine timing to be advanced. Anybody else ever heard of such a thing?
Bruhan
Old May 5, 2007 | 07:49 PM
Drclev3's Avatar
Drclev3
Default RE: Engine Noise
I had a 04 Heritage and I now have a 06 heritage. Both have had the so called noise. I was told the same thing by dealer and by friends that have softails. Not to worry. Get louder pipes and you wont hear a thing.LOL All kidding aside I have had no problems with my bikes my o4 had over 14000 and my 06 has over 3000
Old May 6, 2007 | 12:44 AM
bruhan's Avatar
bruhan
Stage II
Louder pipes are will be on my Christmas list.
Thanks for the advise................
Old May 6, 2007 | 04:41 PM
softail2005's Avatar
softail2005
I find that the adjustment of the primary makes a big difference in noise levels. My bike is an 05 Deluxe and has the manual primary adjuster and once that chain gets a bit of slop in it the sounds can be interesting at different rpm levels. If you have an automatic primary chain adjuster, then that probably is not an issue.
I have heard that there is tranny noise in the 5th gear of the new 6 speed trannys. Baker has a cure for this and its costs about $900 to repair. Down the road Harley may have a fix for that problem.
So I doubt that you are hearing any piston slap at all, the sounds are something else. Piston slap will result in a trashed engine in short order and is usually caused by an inproper bore size or broken rings.
cmas06
Nov 13, 2020 05:58 AM
Falcon195
Aug 2, 2013 04:11 PM
Harley kevbro
Exhaust System Topics
May 17, 2007 12:46 PM
cgarano
Aug 13, 2006 02:05 PM
traveler
13
Jul 6, 2005 04:00 AM
