Wind relief.
Old Jan 11, 2016 | 11:57 AM
Jetfever's Avatar
Jetfever
Thanks Mike.
I looked for the thread, did not find it, after several pages...
Looks like you are doing a great job with the repaint though!!!!
Thanks again, Steve
Old Jan 11, 2016 | 12:15 PM
Mike Lawless's Avatar
Mike Lawless
Thanks again, Steve
Yeah, I'm gettin' pretty excited about it. I should be picking the body work up Wednesday or Thursday. Then I can begin puttin' 'er back together. Hopefully have some new photos up post by the end of the weekend.
Just gotta be careful. Puttin' freshly painted pieces back together is much more tedious than taking it apart. Gotta be careful not to scratch it!
Old Jan 11, 2016 | 12:40 PM
HKMark23's Avatar
HKMark23
Originally Posted by Mike Lawless
I fought with the same issue for several months. I loved riding the bike without the windshield, but the wind pressure was enormous.
I tried various windshield heights, from the "barn door" sized stocker, to a 16" recurve. The helmet buffeting was so severe with the 16" that I couldn't use it.
With nothing to lose, I cut it down. First, down to 11" straight off the top. Big improvement, but still some buffeting. So, I cut 2" off each side and tapered it in on top.
Oh, a buddy with a milling machine modified the SS mount to lay the windshield in closer to the bars. That was a really simple mod. He just cut the top frame channel deeper and trimmed the excess (****) to get them out of the way.
Result - takes the wind-pressure off the mid section, and puts my helmet in clean air. Perfect. Looks good too. Not so overpowering. A clear cut case of "Less is More" and a little less than that is just about right!
You do your own cutting Mike ? Lacking the setup,, or skill,, to do a decent job I took my windshield to an arts/crafts/modeling place, traced out what I basically wanted and let them take it from there. $60 bux but they did a good job IMHO. You can't see from the pic but I needed the headlight opening cut taller and tapered too,, all in the price.
Old Jan 11, 2016 | 12:58 PM
Mike Lawless
Yep. Cut it myself. I do a lot of fab work, so my garage is well equipped. Taped it completely up with blue painters tape and drew the line on one side. Traced that onto some newsprint paper and transferred the shape to the other side so they'd be the same. I used a thin cut-off wheel in my right angle grinder and cut it about 1/8" away from my drawn line, then finished the edge with a flapper sanding wheel.
Old Jan 11, 2016 | 01:08 PM
Jetfever's Avatar
Jetfever
Default flapper sanding wheel
I was wondering how to trim the shield as well.
Flapper sanding wheel...
Like this?
Amazon.com: DEWALT DAFE1H1210 3-Inch by 1-Inch by 1/4-Inch HP 120g Flap Wheel: Industrial & Scientific Amazon.com: DEWALT DAFE1H1210 3-Inch by 1-Inch by 1/4-Inch HP 120g Flap Wheel: Industrial & Scientific
Would this work better, angle grinder flapper wheel:
http://www.alibaba.com/product-detai...280454599.html
Old Jan 11, 2016 | 01:14 PM
Jetfever's Avatar
Jetfever
Default Fang performance/ Running lights and light bar...
BTW, I was wondering why the Fangs work so well on my bike.
I notice a Significant reduction in helmet buffeting and noise.
This MAY be due to the fact I do not have a pair of running lights/ signals next to my headlight. I think it is possible air is directed by the fangs unimpeded up and behind the windshield reducing the low pressure area. I wonder if having a light bar, lights and signals reduce this airflow. I can feel this airflow at the top of the fangs with my hand when at speed.
Many modern bikes have a large relief at the base of the shield for this same reason.
Old Jan 11, 2016 | 02:02 PM
SPRINGER's Avatar
SPRINGER
Just thought that I would throw out a different idea. My Springer is set up in a way to give it an old school look. I have apes on my bike and I didn't really feel like putting a windshield on it because it took away from the look that I was trying to achieve. My solution was a back rest. After I got my back rest, I was around 60 or so, I just lean back on my back rest and my back has thanked me ever since.. just something different to think about.
Old Jan 11, 2016 | 03:05 PM
Mike Lawless
Like this?
Like this one. Available at hardware stores locally.
Jet, aerodynamics are a funny thing. So many things can be different based on riding position, rider height, fore and back lean, etc. It seems there is no "one size fits all" solution to helmet buffeting. I've seen some pretty crazy solutions while looking for fixes. Even HD has a wind splitter windshield to allow wind through, then deflecting it upward. All you can do is try stuff till you hit on something that works.
Springer. Agreed. The back rest is a BIG help too!
Old Jan 11, 2016 | 05:56 PM
AR-15 DEUCE's Avatar
AR-15 DEUCE
Default Windvest
Update....Just got off the Phone with Doug from Windvest..seems like my windshield I got is to low,I sent him pictures with me on the bike,he is sending me out a taller one...#1 in customer service,a real stand up Company.can't say enough..TY
Old Jan 11, 2016 | 06:18 PM
Warp Factor's Avatar
Warp Factor
I'm guessin' he's wrong. You had "nose height" before, and he wants to make the windshield taller. Taller is fine for keeping rain and rocks and birds from hitting you, but is probably exactly the wrong thing for reducing buffeting and strong updrafts behind the windshield.
Better to listen to Mike Lawless.
