Another J&S Jack Conversion
Nice job Op!
I had the basic J&S for about 5 years... loved it!
Then I built myself a 350 sq. ft. shop to work on my bikes with a lift table and a compressor.
I still use the J&S, but felt silly pumping it with my foot with a compressor right there...
So I wanted to see about converting the J&S to air/hydraulic....
I called J&S, since they offer an air/hydraulic version of their jack. They said I couldn't just convert my jack because I would need to change the base plate and other parts...... hmmm
I searched & found the Strongway (#46209) 5-ton air/hydraulic bottle jack. It has about the same dimensions as the manual J&S pump.... close enough to work with.
I was able to mount it to the jack, add the handle, and now I can just wheel it around, hook a hose, and pump it up!
Not being a fabricator, I was able to make it work, but didn't figure a way to align the manual feature so it was accessible....
I posted my conversion and since then a couple of clever people have found a way to mount the bottle so the manual feature is easily accessible.
So we basically now have the air/hydraulic version of the J&S jack for about $70....
So..... "need to", absolutely not..... but "Want to", in my case, yes......
I didn't have a compressor when I bought the J&S jack... air wasn't an option. Once I had air, J&S was NO HELP in my attempt to convert the jack I had. Funny, the guy I talked to at J&S said that converting to air/hydraulic was a constant question... but he said it wasn't doable without totally changing the frame...
So, $549.95 for a new air/hydraulic J&S jack (I don't need 2) or $70 and a about 1 hour from start to finish to convert my J&S (including my simple mind figuring out a way to do it)....
No brainer really....
