Voltage Regulator Wiring Question
Old Mar 16, 2016 | 11:09 AM
coma's Avatar
coma
Default Voltage Regulator Wiring Question
2004 Heritage (FLSTCI) I am replacing a voltage regulator, pretty straight forward I thought, however my bike did not have a wire from the regulator to the main circuit breaker as specified in the manual or in all of the wiring diagrams I saw.
It seems that there should be a wire coming out of the regulator, ran all the way back to the AUX post on the main panel? Can any of you confirm?
When I purchased the bike, the regulator was cracked and hanging, all there was connected was the plug and the ground. I tried tracing a wire to the main panel but there isn't anything.
I know it wouldn't be too hard to just run a wire, but I qm more interested in knowing why my bike did not have one.
Any input/help appreciated
Thanks
Old Mar 20, 2016 | 10:46 AM
gtmalone's Avatar
gtmalone
There has to be a wire from the output of the reg to the circuit breaker and/or the fuse box. Possibly up to the ign switch. As I'm sure you found on the diagrams they all tie together somewhere.
On my '02 the wire runs along the right side of the frame next to the rear brake line.
Check there or see if you have a wire running up one of the down tubes of the frame to under the tank. Maybe they change the wire routing.
Old Mar 20, 2016 | 10:50 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
It doesn`t matter why it was not connected correctly, it just matters that you connect it correctly now.
According to the wiring diagram, the wire from the voltage regulator should be connected to the main breaker, at the silver colored stud (output side of the breaker).
Old Mar 20, 2016 | 05:17 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Schematics, I'd start there. Don't have a manual for your year but someone in here has got one, maybe they'll step up and post a scan.
Old Mar 20, 2016 | 06:15 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Or just read post #3...
Old Mar 24, 2016 | 12:25 PM
coma's Avatar
coma
Thanks guys, yeah I plugged the wire in and followed the wiring diagram, I was just curious and perplexed why that wire was not on mine...
JoeyC013
Ironhead
Sep 23, 2015 06:51 PM
mjaw
EVO
Oct 11, 2014 03:26 PM
bigcountry1764
Oct 17, 2009 07:51 PM
ZuelGodoftheFridge
Sep 17, 2008 10:40 PM
Gem99Ultra
Mar 27, 2008 08:09 AM
