Help with adding LED turn signals
Old Apr 2, 2016 | 05:22 AM
heritageblue2013's Avatar
heritageblue2013
Default Help with adding LED turn signals
2013 Heritage Softail. I did email Custom Dynamics this week. It's now the weekend and they are closed.
Question, do I need a Stabilizer for a 2013 Heritage? Is it in fact a Can Bus system?
I am ordering LED turn signals for front and rear and also getting Custom Dynamics triple play run/brake/turn.
Thanks
Old Apr 2, 2016 | 05:59 AM
kansei's Avatar
kansei
I believe you will need a load equalizer . I have a 2011 Blackline and can have either front OR rear switched to LED but for both I was told I need an equalizer .
Old Apr 2, 2016 | 06:03 AM
owend78's Avatar
owend78
Going off of what their websites states, you do not need one because your bike has a BCM.
Old Apr 2, 2016 | 06:08 AM
Iceman24's Avatar
Iceman24
I believe so...2014+ was a change in electrical not requiring load balancer. If you don't want to wait until Mon, order it & return if not needed...JMO.
Old Apr 2, 2016 | 09:34 AM
FLS103's Avatar
FLS103
I have LED's front and rear on my 2013 Slim and did not need an equalizer.
Old Apr 2, 2016 | 09:40 AM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
On my '13 Blackline, they said I didn't NEED a load equalizer for them to work. All it does is it keeps the dash light from flashing fast, after a few regular flashes. So I left it off.
Old Apr 2, 2016 | 10:08 AM
LA_Dog's Avatar
LA_Dog
Bikes with CAN-bus do not use a load equalizer, only pre-CAN-bus bikes use them. A load equalizer will do nothing on a CAN-bus bike, the BCM module already sees the lower resistance of the led bulbs and adjusts itself automatically. The led turn signals will flash normally, but your dash indicators will blink 2x as fast. AFAIK there is no way to have the dash indicators blink at a normal rate.
Old Apr 2, 2016 | 11:32 AM
heritageblue2013
Thanks for the responses everyone. Im looking forward to the upgrade. Ill update everyone here when I get them ordered and installed.
I wish everyone up north a great beginning to the new riding season, be safe!
Old Apr 2, 2016 | 06:27 PM
jam436's Avatar
jam436
I was told that by Custom Dynamics for my '13 Slim.
First they said I needed one, then they said I didn't.
They included their "can-bus adapter" in the kit they sold me, I installed it and it didn't seem to make any difference.
I still get "burned out lamp" codes with it as well as without it.
Old Apr 2, 2016 | 08:09 PM
70x7's Avatar
70x7
All you have to do is reset the CAN BUS. With the motor off and IGN switch on, run the hazards for 5-6 minutes. Turn everything off and the next time you turn it all on the dash lights will blink normally and you won't get anymore burned out light codes.
