Softail wobble
Old Apr 10, 2016 | 06:11 PM
splattttttt's Avatar
splattttttt
So the steering neck needed tightening? Did you use a touque wrench? Qurious to know how far off rates were to cause it to wobble.
Jbcswifty's Avatar
Jbcswifty
3rd Gear
1998 fxstc softail custom
Old Apr 10, 2016 | 06:15 PM
QC's Avatar
QC
Thanks.
Swingarm bushings are something else to check.
Old Apr 10, 2016 | 06:16 PM
Jbcswifty's Avatar
Jbcswifty
3rd Gear
I just loosens fork pinch bolts and top bolt took a screw driver in there tapped it with a rubber mallet to get it to turn got mabey a quarter of a turn then tighten everything back up
Old Apr 10, 2016 | 07:21 PM
Pitbull_Dallas's Avatar
Pitbull_Dallas
Originally Posted by Jbcswifty
Well when I mean wobble. It's the whole bike feels like it's going from side to side I can let go of the handle bars while it's doing it and it still will go straight down the road with the bike wobbling.
I did tighten head bearings and greased it. And went for a short ride with my daughter and didn't feel anything but didn't really get the bike above 55 didn't won't to spook her if it happened she just started riding this year and loves it
Well, after you get a chance to get it up to speed and if it's still doing it I'd suggest either torquing it to the manual/factory specs or take it to a dealer and let them have a go. After your description I suspect a front end issue. With your description in mind, I had a 51 pan head. Those bikes had a yoke tensioner (tightener) hand nut. Similar to your throttle lock, but larger. You could adjust the yoke tension/tightness on the fly depending on your driving conditions. It could be adjusted to the point that you could barely turn the handle bars if you wanted to. One day I decided to loosen it way up just to see how it would behave. The bike was real loose and wondered badly. It also shimmied, wobbled by your description. Didn't like it at all. I'm thinking that's what your are experiencing.
By the way, I wish Harley still had that feature. The folks that ride the later model bikes don't know what they're missing. It can make riding more pleasurable, particularly on the highway and it can make it handle much better in turns..
Old Apr 10, 2016 | 07:36 PM
chrisj49's Avatar
chrisj49
To adjust it properly requires the fall away test on my 2006 - I think it is the same for your bike. There isn't a torque value for this adjustment.
Highly recommend getting the service manual for your year/model. It will help you as you chase down other little problems, along with giving you all of the torque values and other important info.
Old Apr 10, 2016 | 10:58 PM
balloo's Avatar
balloo
Originally Posted by Pitbull_Dallas
What exactly do you mean by wobble? Front end wobble, the whole bike? While crusing, accelerating or decelerating? On mine there never was any "wobble", but it felt like it wanted to head for the ground in turns, curves and on the grooved road surfaces. In my case the forks/front end wasn't torqued properly and the forks were twisting. You have new tires and bearings so that should not the an issue. If you are hearing any clunks when you hit a bump it could be a front end issue like mine. Maybe yoke bearings..
What did you do about the "clunks when hitting a bump" I have a 2008 and it has done it since I got the bike. Had 3500 miles when I bought it, and now has 20,000. No problems with handling.
I just thought it was a rattle coming from the windshield mounts.
Thanks for a response.
Old Apr 11, 2016 | 12:47 AM
Next In Line's Avatar
Next In Line
Everything that needs to be checked for the wobble should include, but not be limited to:
• Air Pressure
• Rear Wheel Alignment 0.793mm In Between Side To Side
• Tires Not Balanced
• Rim / Tire Out Of Round
• Steering Head Bearing Incorrectly Torque
• Wheel Spacers
• Wheel Bearing
• Engine Mount
• Transmission Mount
• Equal Amount Of Fluid In Both Forks
• Loose Axle Nut
• Caliper Alignment
• Neck Bearing Adjustment
• Swing Arm Pivot
• Shocks Rear Aligned Equally
• Top Of Forks Not Extending More Than 10.66mm - 12.7mm And Be Equal
• Steering Stem Nut
• Swing Arm Bushings
Old Apr 11, 2016 | 12:02 PM
Pitbull_Dallas
The clunk a supposed to be an incorrectly tightened yoke. It was a question that was asked of me by the dealer when I was having my front end issue. The clunk is caused by the looseness and is pretty definitive when it happens. In my case they retorqued everthing on the front end.
If you say it's done it since you got the bike, you likely don't have a problem. You're probably hearing something else..
Old Apr 11, 2016 | 12:30 PM
2015 Harley Davidson Street Bob Guy's Avatar
Why dont you get it fixed by the dealership? I would never let someone ride on the back of my bike especially my daughter if the bike wobbles.
